Tip & How-To about Logitech Extreme 3D Pro Joystick
Installation, and testing the Logitech Extreme 3D Pro Joystick
The joy stick comes with a CD. Put the CD on the tray, and let the computer runs the software. On the CD there are driver for the joy stick itself, and driver for the USB . click on install joystick, after that, click on install the USB drive. that is it. Then a test screen will appear and asks you to check your joystick movements and buttons .push on the buttons,on the joystick, and you will see that they turn red on the computer screen each time you push a button, meaning your computer reads the commands from the joystick, You are set.
If you do not have the CD, then go to the Logitech site. and go to support, and from there you can download the drivers for the joystick.
Logitech Extreme 3D Pro Joystick Logo
surpermtine belt diagram
Jan 17, 2013 | 2007 Dodge Caliber 2.0
0xc000014c
A recent hardware or software change might be the cause. To fix the problem:
1. Insert your Windows installation disc and restart your computer.
2. Choose your language settings, and then click "Next."
3. Click "Repair your computer."
If you do not have this disc, contact your system administator or computer manufacturer for assistance.
File: \Windows\system32\config\system
Status: 0xc000014c
Info: Windows failed to load because the system registry file is missing, or corrupt.
She did not have a Vista CD, as her PC came with it on, so I told her I would try my CD, I put in the CD and the same screen came up and would not change.
So I change the boot order, to start with CD/DVD first and still no change, it still starts up with that same screen.
So I copied the Vista CD to my memory stick and changed the boot order to run with USB first and no joy again.
I have run the boot in all of these orders with no joy:
CD/DVD
USB
Hard drive
USB
CD/DVD
Hard drive
Hard drive
CD/DVD
USB
Cheers,
Robin
Apr 27, 2012 | Sony VAIO Notebook PC VGN-NS235J/W
HOW TO OPEN TO INSERT CD INTO DLINK ROUTER
The DVD/cd-rom that comes with the router is so you can setup software on one or more of your computers to manage the router.
So you will place it in the cdrom drive of one of your computers that is hard wired to the router (cable should have also been provided) this allows you to setup things like wireless with security and password protection of the router itself.
Although it isn't the only way to set it up. It is most of the times simpler to configure the router with their software.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Oct 04, 2011 | D-Link DIR-615 Wireless Router
I have just purchased a TDK TF250 Memory Stick to download pictures from my computer. Being a complete novice and with NO INSTRUCTIONS in the pack, what do I do?
if it is just a USB 2.0 stick you just put it into the USB port on your computer and if it didnt come with a CD then it will have the install software on it and will just do everything itself however if it came with a CD then install that before you plug the stick in and everything should work fine after that
Sep 18, 2011 | Computers & Internet
DIsk drive ejects disk tray after 10 or so seconds. It will shut itself again, then eject again. This happens when I put in a DVD, not sure if it'll happen with a CD yet.
Reinstall the driver running it... go to "Device Manager" and right click on the cd-rom icon and select Properties. in that section you will find the options for handling the driver software...
Mar 08, 2011 | Creative Labs (CD5233E) Internal 52x...
1,391 people viewed this tip
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
