Tip & How-To about Exercise & Fitness
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
Exercise & Fitness Logo
Life Fitness 95xi elliptical electronic panel will turn on but after a few seconds the screen goes blank and evenutally starts back at start up screen.
I would suggest verifying 6 volts output from the battery. From there, check the reed switch connection on the power control board. Also verify the gap between the reed switch and the magnet on the pulley. It needs to be close enough to the magnet to get a good reading. I am attaching a link to a video that shows the reed switch replacement procedure. You can see the magnet and also the slots in the reed switch that allow the adjustment. LifeFitness 95Xi Crosstrainer Video Reed Switch Replacement Speed Sensor
Mar 18, 2014 | Life Fitness 95xi Elliptical Crosstrainer
where is the battery on the life fitness 95xi
The battery is located in the front of the rear drive mechanism. It is mounted just below the alternator control board. The following video shows the battery location along with the battery replacement procedure. Battery 6 Volt 2 5 Amp Hr LifeFitness 0017 00003 0685 SPORTSMITH net
Dec 29, 2013 | Life Fitness 95xi Elliptical Crosstrainer
513 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
