Tip & How-To about Casablanca Fan (1928D) Table
Casablanca Table Fan, DOA
If your Casablanca Fan (1928D) Table Fan has stopped working completely, or stopped in the middle of oscillating, it might be the internal AC wire that runs up the middle of the fan base, that is broken internally. First, make sure the fan is not plugged in. You have to take the whole fan apart from the front. Check for continuity on the white and black wires that run to the motor. You may have to pierce the black and white wires with a pin to check them, because they are wired directly into the motor. These two wires have a black jacket covering them that can be pulled off if you find an open wire. Either one of these wires can break internally because of the back and forth movement. Cut the wires close as necessary to the motor to make the splice. Solder and use heat shrink insulation and route the new wire back down through the base and splice them where the original wires were. I used a piece of electrical cord with white and black conductors that was cut off an appliance that was dead. It was the same size as the original so it fit well. Please note, this repair requires electrical and mechanical knowledge. You have to take the whole fan apart to do this repair.
Casablanca Fan (1928D) Table Logo
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Need a internal wiring diagram for a Casablanca Fan P4M55H
    I don't think you can do that if it came with a built-in receiver.
    Jul 07, 2014 | Casablanca Fan P4M55H Cosmopolitan...
    casablanca zephair
    The on Zephair came with the old intellouch control,which is a special control for that fan. If that is what you have then call 1-800-715-0393 with model# & serial#
    Mar 24, 2013 | Casablanca Fan 1928C Zephair Satin Brass...
    oscillating table fan makes banging noise when rotating
    mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
    Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
    Casablance Ceiling Fan Trouble
    itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
    Jul 16, 2008 | Casablanca Fan 3245T Ceiling
    1,094 people viewed this tip
    Top Casablanca Fan Dryers Experts
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
    Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
