Tip & How-To about RIM BlackBerry Curve 8520 Smartphone
How to wipe the data from blackberry
Open setting then click option
click wipe the security data
then type password blackberry
mobile was wipe
RIM BlackBerry Curve 8520 Smartphone Logo
i want to reset my blackberry 8300 passwor?
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
OR:
Type password Ten times incorrectly ..this will wipe off all the data and will restart your blackberry
and when it is restarted you will be able to enter a new password and in Case if you donot want to Wipe the data and still you want to reset it..if you are on the main screen of your blackberry
Settings--options--security settings or security options and than press on track ball or wheel and from the menu choose reset Password..
Aug 22, 2010 | AT&T Blackberry Curve 8300 Smartphone
in my att blackberry it says error 507 how do yu fix that
To solve Error 507 You need to update/ReInstall the BlackBerry Operating System.
With error 507 appeared on display, during update sw ask device password,just type any password what you like 123456789..
how to reset blackberry password ?
Enter wrong password 10 times your device will deletes all your device data & reset user password
Note : If you type your BlackBerry® device password incorrectly , you might be prompted to type blackberry before you can continue.
you need to remove IT policy , here is the working solution how to remove IT policy tested by me many times
Go to your Options : Security >> Security Options (the same page where you can enable/disable passwords) & scroll to the bottom. If there's an IT policy attached, it will be mentioned there. Remove the IT policy using these instructions
Procedure
Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here.
Step 2 : Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry).
Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts.
Step 4 : Close the Desktop Manager if it is open.
Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to:
HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager
Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to:
C:\Program Files\Research In Motion\BlackBerry\policy.bin
Step 6 : Open the Desktop Manager.
Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications.
Nov 24, 2009 | Cell Phones
how to master reset a blackberry pearl 8220
To delete all data and applications from your BlackBerry smartphone, complete the appropriate set of steps below depending on the version of BlackBerry® Device Software you are running. Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data prior to wiping your BlackBerry smartphone. If content protection is turned on, the process for deleting all data and applications from the BlackBerry smartphone can take up to an hour to complete. Do not remove the battery from the BlackBerry smartphone while data is being deleted. To identify your BlackBerry® Device Software version go to Options > About (For example, 2.6.x.x, 2.7.xx or 4.0.x.x) For BlackBerry smartphones running BlackBerry Device Software version 2.6 Note: If a password is already set go to step 5. On the Home screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. In the Password field, press the Space key to enable the password. A dialog box prompts you to type a password with at least four characters. Type a password. Click the trackwheel. Type your password again to verify it. On the Home screen, click the ?Lock? icon. The Lock screen is displayed. Enter your password incorrectly 10 times to trigger a security wipe. For BlackBerry smartphones running BlackBerry Device Software version 2.7 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld? For BlackBerry smartphones running BlackBerry Device Software version 4.0 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld?. For BlackBerry smartphones running BlackBerry Device Software 4.1 to 4.2.1 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Click Continue. Type blackberry, and then press the Enter key. For BlackBerry smartphones running BlackBerry Device Software 4.2.2 to 4.7 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Select the Include third-party applications check box if you wish to remove third-party applications. Clear the check box if you do not want third-party applications to be removed. Click Continue. Type blackberry, and then press the Enter key.
Oct 29, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
change the language in a blackberry tour
you need to wipe the device, as in bring it back to factory settings, you will lose all data and contacts on the device.
1. In the device Options, click Security. If you are using BlackBerry Device Software 4.1, click Security Options > General Security.
2. Click the trackwheel and select Wipe Handheld.
3. Click Continue.
4. Type blackberry. All the data on the BlackBerry device is erased.
Sep 30, 2009 | RIM BlackBerry? Tour 9630 Smartphone
1,978 people viewed this tip
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
