Tip & How-To about Computers & Internet
Useful Tips to Choose the Best Gaming Motherboard
Motherboard is the heart of the whole computer system. It is the part that connects all the other parts together and make sure they run smoothly. As such, choosing the best gaming motherboard is the most important task that you need to do when building a gaming computer. This article will teach you how to choose the best gaming motherboard.
Decide which type of CPU to use
This may seem irrelevant to choosing a motherboard. In actual fact, this is the most important thing you need to do before selecting a motherboard. The reason being that the type of CPU will determine the type of motherboard you need. For example, if you choose an Intel CPU, then you have to get the socket 775 motherboard or else the CPU won't fit into the motherboard. Deciding on the type of CPU will help you to make a better choice when choosing the best gaming motherboard.
Determine if the motherboard supports the type of CPU you have chosen
As mentioned before, if you are using an Intel CPU, you have to get a socket 775 motherboard whereas an AMD CPU requires a socket AM2 motherboard. In addition, some of the older socket 775 motherboards do not support dual core processors (even though they use the same socket) or even quad-core processors. Check out the manufacturer's website to get confirmation before you buy the motherboard.
Overclocking feature
If you are overclocking your CPU, you have to get a motherboard that allows you to change the FSB speed and CPU voltage in small increments.
RAM support and no of memory slot
Your motherboard must be able to support DDR3 RAM, for a simple reason that DDR3 is currently the fastest RAM in the market. Extra thing to take note is the maximum speed of RAM that the motherboard supports. Some motherboards can support only up to DDR2 667MHz RAM while the latest ones can support up to DDR3 1066MHz.
In addition, you may want to upgrade your RAM in the future, therefore your current motherboard must have at least 4 memory slots and can support up to 16GB RAM so that you have the option to upgrade in the future.
SLI/ Crossfire ready
SLI / Crossfire ready motherboard means that you can make use of two identical high performing graphics card to render the graphics, thus achieving a faster and more realistic video effects. Not every motherboard supports this feature. As video effects getting more and more advanced, it will be soon that SLI or Crossfire technology becomes the standard for video display. Therefore, even if you are not using this technology now, it is still advisable to get a gaming motherboard with SLI or Crossfire feature.
SATA 2 controller
SATA2 can transfer data at twice the speed of SATA 1. When it comes to gaming, every single speed counts and that increase in speed might be the deciding factor in your game. A SATA 2 port is backward compatible with SATA 1 devices, but not the other way round. It is better for you to get a motherboard that supports SATA 2 devices. In addition, if you are using RAID, then you have to get a motherboard that has four SATA 2 ports.
Extra Features
You might want to consider extra features such as extra USB2.0 ports, firewire, integrated LAN and front-panel LED when choosing a gaming motherboard. Some of the motherboards contain more features than the other and you have to compare around to see the differences.
Features such as integrated sound and video are not as important in the best gaming motherboard since they could not contribute well to a good gaming session. For a gaming computer, you have to get a separate graphics card and sound card so as to play the latest game in the market.
Conclusion
When getting the best gaming motherboard, it is worthwhile to do some market research and compare with various boards. Since it is the most important part in the whole computer system, don't ever scrimp money on it.
Computers & Internet Logo
replace motherboard
What is the make and model? Be sure you purchase the correct replacement with the same suffix otherwise your chip set will not match your drivers.
Nov 22, 2013 | Computers & Internet
for my '89 volvo 240 i need to change the water pump and i feel like i'm doing it wrong cause i'm basically take off the whole front of engine
It has been many years, but I am pretty sure that there is not much that you have to take off. Just the fan and maybe the top plastic timing belt cover.
Be sure to take steel wool and smooth the tip of the water pipe that runs along the exhaust side of the engine block so it gets a smooth seal where it presses in to the new water pump. Also smooth the bottom of the head where the water pump fits up beneath it.
The tough part is keeping the O-ring on top of the water pump from leaking because there is no bolt that holds that seam tight together. What you do is - you snug the bolts that hold on the water pump, then take a lever and pry upward on the water pump to squeeze that O-ring while tightening the bolts the rest of the way.
Aug 23, 2011 | 1989 Volvo 240
After installing Windows XP, the whole process runs smoothly, the redemmarrage, it gives me error codes and the computer crashes, what's the problem
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work but if it is hardware related
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or faulty fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also check the Cmos battery and computer ram make sure they are securely seated
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system information all of your computers information will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Aug 03, 2011 | EliteGroup ECS P4VMM2-8.1 PRESCOTT CPU...
hp/sceen/hard drive/motherboard
video onbord is going bad and screen and or connection to it on hp will need whole new mobther bord from ober heating using it on bed cant **** heat from botttem out back so it overheats kills parts
Oct 06, 2008 | HP Pavilion dv6000z Notebook
light is solid yellow on front switch, won't boot
if you are certain the power supply is good(try it in another machine) and its completely connected it sounds as if your motherboard is going bad, there is a 5-volt supply in your power supply that does not turn off when the system shuts down, its called 5-volt standby, this runs some small circuits on the motherboard that monitor the power switch, when its pressed the circuit starts up the whole power supply. thats how we can power off the system with software. usually its a custom chip and some components, but without the schematics of the motherboard and the replacement parts and the ability to de-solder and solder on a multi layer board its not usually repairable by the end user.
the system memory and processor are not even used in this part of the system startup, they come into play after the supply is up and stable and supplies the power good line to the motherboard.
make sure the supply is good, and all connections are making contact, that none of the pins have backed out of their housings when being plugged in and that there are no cracks in the solder joints where the power connectors attach to the motherboard.
Oct 17, 2007 | Computers & Internet
1,216 people viewed this tip
David Payne
David Payne
