Home | All Products | Playstation 3 (PS3) Console | Tips
My Playstation does not read any disk
ginko
By Guru ginko
Rank: Guru
Rating: 89%, 4894 votes
posted on Jun 18, 2009
Very Helpful
When your console does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the PS start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the PS, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before doing tis, contact Sony to check if the unit can be replaced or repaired by Sony, you find the number on the Console documentation.
Things work in the same way on Xbox, Just contact Microsoft instead than Sony.
Was this helpful?
Yes
No
29 people thought this was helpful
Comment #1
posted on Jun 20, 2009
Ekse
By Guru Ekse
Rank: Guru
Rating: 88%, 4595 votes
DVD lens cleaner is not recommended and may void your warranty.
A DVD lens cleaner will very likely make the problem worse Sony warns against doing this and If my memory serves me right it might void the warranty as the disc can ruin the lens on the blue ray drive.
Disassemble and cleaning the lens is a better option
. Even better, just contact sony directly about it, if your on warranty its free repair, outside of warranty its 150 at that point you should try cleaning the lens.
heres how to clean the lens
Can you Help with these Video Game Consoles problems?
Sony Playstation 3 (PS3) Console
the picture wont show up on my tv using the hdmi hook up...
mad catz controller wont sync to ps3
it wont let me put a cheat code in for mid night club los...
I hooked my play station 3 into my granddads tv and can't...
I used to play online until one day the whole network in...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
