Tip & How-To about Garden
Setting a carb
Http://www.tillotson.ie/docs/techinfo_HS_US.pdf
The best answers come from the folks that make the carbs
Garden Logo
how do you set up a carbaretta on a flymo petrol qs46sd
2 stroke or 4 stroke engine? Check out the link from "tillitson" 2 stroke carb theory. GOOD LUCK http://www.tillotson.ie/docs/techinfo_HS_US.pdf
Apr 15, 2014 | Garden
need craftsman chainsaw manual
2 cycle engines almost all share the same characteristics when setting the carb. this link should get ya going. remember if the piston is damaged you wont pump fuel. carb adjustment screws dont adjust themselves. google(piston blow by) http://www.tillotson.ie/docs/techinfo_HS_US.pdf
Feb 07, 2014 | Craftsman Garden
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
845 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
