Tip & How-To about Toshiba Satellite Computers & Internet
How to restore factory default
Toshiba laptops from mid-2007 onwards don't have a recovery disc supplied with the laptop. Instead, Toshiba has added a hidden partition on the hard drive which contains the same files as a recovery CD/DVD.
WARNING: All data and added programs will be deleted with this procedure. This procedure puts your laptop back to it's initial "out-of-box" factory settings. Make sure you save any critical data onto another device (CD, Flashdrive, External Harddisk, etc) before performing this procedure.
To restore your laptop to its factory settings using the hidden partition:
  1. Hold down the power button for ten seconds to switch off your machin. Please note that holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
  2. Press and hold the zero key and at the same time, tap the power button once to power on your notebook
  3. When the machine starts beeping, release the zero key
  4. When prompted by the warning screen, select Yes to continue with the system recovery 5) Select Recovery of Factory Default Software and click Next
  5. Select Recover to out-of-box state and click Next again
  6. Click Next to Start the recovery
Computers & Internet Logo
how do i factory restore my toshiba satellte P750/P755
Toshiba laptops from mid 2007 onwards don't have a recovery disc supplied with a purchase of a laptop
Instead, Toshiba has added a hidden partion on the hard drive which contains the same files on a recovery CD/ DVD.
To reinstall your laptop to the factory settings/ "out of the box" settings, please follow these steps. It worked for me, and should work for you.
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
I hope you find this step by step solution helpful for you.
Jul 08, 2011 | Computers & Internet
how to reset toshiba laptop to factory settings. Without original disc
Toshiba laptops from mid 2007 onwards dont have a recovery disc supplied with a purchase of a laptop. Instead, Toshiba has added a hidden partion on the hard drive which contains the same files on a recovery cd / dvd.
To reinstall your laptop to the factory settings / "out of the box" settings, please follow these steps. It worked for me, and should work for you.
Thank You
Oct 29, 2010 | Computers & Internet
restore my toshiba laptop to factory settings
6) Select Recover to out-of-box state.Click Next again.
Oct 26, 2010 | Computers & Internet
how can i set my toshiba satellite a215 s7422 back to factory settings?
Apr 08, 2010 | Toshiba Satellite A215-S7422 Notebook
4,285 people viewed this tip
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
