Tip & How-To about Microwave Ovens
Using stainless steel utensils in a microwave oven
Every one knows that one cannot use metal utensils/bowls in a microwave oven.
But did you know that this does not apply to a utensil/bowl made out of stainless steel?
Try it this way.
Put some water in a stainless steel container and place it in the microwave for 5 seconds.The water will heat up without any sparks being created.
One could actually heat up anything in this way without any danger of causing a fire.
Microwave Ovens Logo
micowave continues running after time is up
This can be two things that I know of 1 is a timer defect and the other is someone has placed some type of metal ie utensil, foil, can whatever into the microwave - either way you should replace the microwave and its a fire hazard to your home and others around you and the cost of a new unit is not worth the losses a fire can bring.
Jan 14, 2013 | Maytag Appliances Over-the-Range Microwave...
As plugged in microwave starts up doesn't stop even if you press clear and it also sparks where can i go to exchange it or have it replaced?
Sounds like someone tried heating something up with metal attached or possibly left a utensil, Chinese food with the metal handles or foil in the unit - throw it out and but a new unit - it's not worth it parts plus labor and it will never work right again the power scale will be off
Jan 14, 2013 | Emerson MW8777W Microwave Oven
can i put the crock pot bowl in the oven and cook in it
A Crock Pot is made of crockery and is OK to bake in the oven. Don't let it get into contact with cold items, water etc, when it is straight out of the oven or it will crack, like any other crockery utensil. Treat it like glass.
Dec 30, 2010 | Microwave Ovens
I was afraid to keep using the oven
Look to see if there may be a small piece of metal, or aluminum somewhere in the oven or in the food, also it may be the utensil you have the food in is not microwave safe.
The Microwave oven won't hurt you microwaves are about the size of a pencil.
Feb 10, 2009 | Sharp R-1480 Microwave Oven
598 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
