Tip & How-To about MSI Ms-6741 Ver:1 Pc Motherboard Amd Athlon 64 Ada3000aep4ax 2ghz Processor
Is it possible to install Windows 7 ?
Hello, I'm having troubles with installing windows 7 and i'm afraid it's caused by this mainboard - any advice?
MSI Ms-6741 Ver:1 Pc Motherboard Amd Athlon 64 Ada3000aep4ax 2ghz Processor Logo
what to install to run games in window 7 with intel 845 motherboard when error is install d3d drivers
Hello here is the homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVSR
Your mainboard is to old to run windows 7, here is no drivers for the operating system.
Windows xp and older is a supported system.
You have to buy a new pc or a new mainboard, to support windows 7.
Good luck
Sep 16, 2013 | Intel D845GVSR Motherboard
Gigabite Motherboard Audio Drivers Problem. Plz Help!
Hello try to find the mainboard here:
http://www.gigabyte.com/support-downloads/download-center.aspx?ck=2
By entering the mainboard number.
I suggest you try the vista sound driver, when windows 7 is not supported.
The vista driver sometimes work, on your windows system.
Good luck
Mar 27, 2013 | Computers & Internet
I installed windows 7 but my vga(via p4m266a) doesn't support how can i fix it
Hello if it is this mainboard:
http://www.asrock.com/mb/VIA/M266A/?cat=Download
It`s to old to run windows 7 with the onboard graphic.
And the driver does not supports windows 7.
You can add a new graphic card in the agp 4X
socket on the mainboard.
Just make sure the graphic card driver supports windows 7.
Good luck
Dec 05, 2012 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
what year was dell latitude d510 introduced and does it support windows 7
  • It was introduced around 2005. It lacks the RAM necessary to run windows 7 (It has 512 MB, when you need 1 GB). So, I'm afraid this computer is not compatible with windows 7 unless you upgrade the RAM
  • Please reply if you have any more questions. Good Luck! Please give 4 thumbs up if I helped!
Jul 08, 2011 | Computers & Internet
3,452 people viewed this tip
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
