Tip & How-To about Thule 668 Frontier ES Roof Box - LL Bean
How to fit a roof box
A roof box is one of the best ways to increase the capacity of your car - but are the easy to fit? We spoke to an expert at Thules who gave us a tutorial on how to do it...
Thule 668 Frontier ES Roof Box - LL Bean Logo
Will a 1995 to 2002 Camero LH power seat track with harness and 6 way switch fit a 1985 to 1989 Olds Regency 98 Sedan? Will I have to modify any wiring ? Thanks
If you do not know everything there is to know about car electricity, you will real soon.
Yes it will fit.
The good news is that I just spoke with an Oldsmobile expert on the phone, and he said the Regency has a driver's side electric seat option.
All you have to do is plug it in where that original wire is supposed to go in the fuse box, and you are good to go.
The original circuit was not in the front of the fuse box, it was wired in to the back as a factory installation.
You will need to do that.
If you will find an Oldsmobile Owner's manual, it should have the location for the electric seat fuse, unless it is a circuit breaker.
Either way, hook it up like the original was to prevent a fire.
God bless your efforts.
Apr 12, 2016 | Seat Cars & Trucks
increas channel capacity in bpl prima tv
BPL Prima has the capacity of 100 programs only. There is no other way to increase its capacity.
google.com/+GopakumarGopalan Gopakumar Gopalan Google
Apr 10, 2014 | Televison & Video
line crack of roof.
I have a solution for cracking of these Thules.
The stores that sell these, carry a patching kit. It's a 3x8" piece of the same material with adhesive on one side. You can take a heat gun and soften the patch and place it over the crack and shape to fit before it cools. I've had 2 Thules on the roof of my excursion with stress cracks at the anchor points. This stuff really does the job and it's really inexpensive.
I have them on both boxes at all stress points... It has solved this issue.
Aug 14, 2010 | Thule 668 Frontier ES Roof Box - LL Bean
are they easy to fit diy bmw z
Not sure about the bmw specificly BUT it is indeed hard, you need special tools and it's best left to a pro who will no doubt charge 1000 or more dollars to replace the convertable top.
Mar 30, 2010 | 1998 BMW Z3 Roadster
Easy Heat roof deicing cable with a nick
cut the cable and rejoin with snap joint the cover with insulation tape that should do the trick
Nov 14, 2009 | Easy Heat Water Pipe Heating Cable
585 people viewed this tip
Top Thule Winter Sports Experts
ray gallant
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
