Tip & How-To about Elna Heirloom Edition 6005
Heirloom 6005 won't do decorative stitches or zig.....
I found out the hard way. If your machine just refuses to do any zig zag or decorative stitches..check the Twin Needle Key. I replaced the mother board at a cost of $400 and then found out that was the problem.
Sewing Machines Logo
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Oct 20, 2014 | Kenmore 19233 Computerized Sewing Machine
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
What foot do I use with the twin needle?
You need to use the zig zag or satin stitch presser foot with the twin needle. You also need to make sure you have the zig zag plate on your machine. Also, remember when using the twin needle, you cannot put your stitch width beyond half way. The best thing to do is once you select the width, turn the handwheel to see where the needle is going to hit, you want to make sure it clears the plate or it will break.
Feb 09, 2009 | Brother LS-2125 Mechanical Sewing Machine
922 people viewed this tip
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
