Tip & How-To about Mevinv Web Development Facebook Apps
How to add images in your web site
To display an image on a page, you need to use the src attribute. Src stands for "source". The value of the src attribute is the URL of the image you want to display.
Facebook Apps Logo
What is the weight? Could it be lifted into a car?
Just Google the model and you will see specs like this. This one would be a two man job to lift!
Product details have been supplied by the Manufacturer, and are hosted by a third party. Overview
  • .w480.jpg"> The Ezee Life EZee Rovers electric mobility scooters are the only mid-size folding scooter on the market, providing a sporty yet strong design which makes it ideal for indoor or outdoor use. The 15.5 miles cruising range means it can keep up with you all day long! This sleek electric 4 wheel scooter is one of the safest rides on the market and includes tail lights, turn signals, headlights, and running lights to make sure you stay accident free. The amazing four point seat structure means 45% more stability on inclines. All of these safety features and a luxurious Memory Foam seat too? You can trust Factory direct, your Toronto source for Medical supplies for the home, for value and friendly service.
Scooter Features {"tourViews":[{"viewImage":{"runtimeSrc":{"height":566,"width":673,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.web.v1.jpg"},"src":{"height":566,"width":673,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg"},"sources":[{"height":566,"width":673,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.w960.jpg","profile":"W960"},{"height":403,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.w480.jpg","profile":"W480"},{"height":201,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.w240.jpg","profile":"W240"}]},"hotspots":[{"hotspotX":0.30357142857142855,"captionFromAttr":"Control Panel","direction":"left","description":"Functionality Description<br/>1. Operating Key Main On/Off switch (power source) for the Rover. (Remove the key when the scooter is not in use)<br/>2. Operating Lever (Left/Right) Moving the lever controls the speed. To drive forward, pull the right lever toward you and push the left lever away from you. Releasing the lever will bring the scooter to a gradually stop. To drive backward, pull the left lever towards you.<br/>3. Horn Pressing the button sounds the horn.<br/>4. Manual Speed Adjuster. The maximum speed is 11 km/h. Rotating the button to the lower speed (turtle icon) will reduce the speed, for slower, gentle operation.<br/>5. Turn Signal Operates the turning signal lamps<br/>6. Hazard Lights Signal Operates the emergency warning lights.<br/>7. Speed Selector Switch Set the switch to the lower speed (turtle icon) position for slower operation.<br/>8. Battery Charge Indicator Shows the state of the battery whenever the scooter is operation.<br/>9. Operation Indicator Shows operational faults<br/>10. Lights Switch Turns the front and rear headlights on and off.<br/>11. Hand Grips Flexible hand grips for comfortable hand support.<br/>12. Tiller Handle Adjusts the tiller to your preferred position.","hotspotY":0.11063829787234042,"media":{"runtimeSrc":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.web.v1.400.jpg"},"src":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png"},"type":"IMAGE","sources":[{"height":662,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.w960.jpg","profile":"W960"},{"height":331,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.w480.jpg","profile":"W480"},{"height":165,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.w240.jpg","profile":"W240"}]}},{"hotspotX":0.425,"captionFromAttr":"Tiller","direction":"right","description":"Tiller for folding control panel for easy storage/transportation","hotspotY":0.11914893617021277},{"hotspotX":0.6035714285714285,"captionFromAttr":"Locking Handle","direction":"left","description":"Locks front and rear compartments (located under seat)","hotspotY":0.4595744680851064,"media":{"runtimeSrc":{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.web.v1.jpg"},"src":{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg"},"type":"IMAGE","sources":[{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.w960.jpg","profile":"W960"},{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.w480.jpg","profile":"W480"},{"height":131,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.3107142857142857,"captionFromAttr":"Headlight","direction":"left","hotspotY":0.37872340425531914},{"hotspotX":0.7428571428571429,"captionFromAttr":"Folding Seat","direction":"right","hotspotY":0.14468085106382977,"media":{"runtimeSrc":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.web.v1.400.jpg"},"src":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg"},"type":"IMAGE","sources":[{"height":662,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.w960.jpg","profile":"W960"},{"height":331,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.w480.jpg","profile":"W480"},{"height":165,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.6678571428571428,"captionFromAttr":"2 x Battery Packs","direction":"right","hotspotY":0.3148936170212766,"media":{"runtimeSrc":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.web.v1.400.jpg"},"src":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg"},"type":"IMAGE","sources":[{"height":845,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.w960.jpg","profile":"W960"},{"height":422,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.w480.jpg","profile":"W480"},{"height":211,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.8142857142857143,"captionFromAttr":"Rear Signal Lights","direction":"right","hotspotY":0.502127659574468,"media":{"runtimeSrc":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.web.v1.400.jpg"},"src":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg"},"type":"IMAGE","sources":[{"height":845,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.w960.jpg","profile":"W960"},{"height":422,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.w480.jpg","profile":"W480"},{"height":211,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.30714285714285716,"captionFromAttr":"2 Front Wheels","direction":"left","hotspotY":0.7617021276595745}]}],"ipiCompatible":false} ?environment-id=live&enable-reporting=true&suppress-site-prefs=true&showtabs=false&wc-target=mobile&show-tabs=false&from-pp=true" data-wc-rel-click-name="eliminate-zoom-report" wcobj="http://media.webcollage.net/rwvfp/wc/cp/17997184/module/factorydirectmedical/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/tour" wcobj-height="450" wcobj-id="wct-6283c5c4" wcobj-type="video/x-tour" wcobj-width="800"> .w480.jpg" alt="Product Tour"> > Click to Start Features
  • Battery Light Indicator
  • Keyed Ignition
  • Delta Tiller
  • Full Light Package
  • Deluxe Memory Foam Seat
  • 12 inch Pneumatic Easy Ride Tires
  • Adjustable Tiller
  • (Virtual Adjustment)
  • Folding Tiller
  • Folding Frame
  • Light Weight Alloy
  • Speed Control
  • Reverse
  • Ultra Lightweight
  • Easily Folds
  • Fits In The Trunk Most Any Car
  • Rear Wheel Drive
  • Car Charger
  • Electronic Automatic Brakes
  • 375 lbs weight capacity
Sep 21, 2015 | Health & Beauty
how do I get pictures and sound on web pages
You can add an image using the following html: <img src="imagename.ext" alt="Alternative text foe screen readers or in case the image doesn't show" /> and audio using the following format:
<audio controls>
<source src="file.ogg"type="audio/ogg">
<source src="file.mp3"type="audio/mpeg">
Your browser does not support the audio element.
</audio>
Oct 15, 2014 | Microsoft Internet Explorer 8
looking to find camshft sensor on 2002 land rover any help. I would be so thankfull.
On an overhead camshaft engine, look for the camshaft sensor near the end of the camshaft pulley area on the left or right side of the engine.
Camshaft Position Sensor Operation:00158_camshaft_position_sensor.jpgA magnetic or hall effect sensor. It sends a signal to the computer relaying information about shaft speed, position and acceleration or deceleration. This information determines when the fuel/air mixture needs to be ignited and how much mixture is needed for the engine.
For your 2002 Land Rover Freelander AWD 2.5L MFI 6cyl Part Number:
SU6389
function linkImage(newLink){ var url = newLink.href; if (url.indexOf('prodImageURL') == -1) { newLink.href = url + "&prodImageURL=" + document.getElementById("enlargedImage").value; }else { newLink.href = url.substr(0 , url.indexOf('prodImageURL')) + "prodImageURL=" + document.getElementById("enlargedImage").value; } } function changeImage(filename) { document.getElementById("mainimage").src = filename + '2/'; document.getElementById("enlargedImage").value = filename; }
function linkImage(newLink){ var url = newLink.href; if (url.indexOf('prodImageURL') == -1) { newLink.href = url + "&prodImageURL=" + document.getElementById("enlargedImage").value; }else { newLink.href = url.substr(0 , url.indexOf('prodImageURL')) + "prodImageURL=" + document.getElementById("enlargedImage").value; } } function changeImage(filename) { document.getElementById("mainimage").src = filename + '2/'; document.getElementById("enlargedImage").value = filename; } Good luck on this repair.
Nov 03, 2010 | 2002 Land Rover Freelander
SNML validation error: img: requires the 'src' attribute. Keeps coming up on one of my friends pages cant get the page open can you help please
It would appear that the image on the page requires a location of where the image file is located, so that the browser can find it and display it. It woul appear your friend is developing his own web site? It's rather odd that the rest of the page does not display, unless the page IS the image and there's no text or other components on it. Ask your friend to correct the problem by linking the image to a physical location either on a physical or relative location. If he's into HTML and web programming, he'll understand you.
Oct 27, 2009 | Microsoft Windows Vista Ultimate Edition
634 people viewed this tip
Top Mevinv Web Development Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Mevinv Web Development Facebook App Expert? Answer questions, earn points and help others
