Tip & How-To about Brother MFC-9420CN All-In-One Laser Printer
Can not print check T S manual
If you have this  turn machine on press menu blach copy up arrow button 4 times
this will take you to mant. enter 82 and it will give you the er code
Brother MFC-9420CN All-In-One Laser Printer Logo
fix volume control
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
I’m happy to help further over the phone at https://www.6ya.com/expert/glenn_3b3dd885737c06f6
Aug 09, 2014 | Yamaha RX-V757 Receiver
error 46
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Solution no. 2. (DCP 115):
Here's how...
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value which is I assume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set". Do the same for numbers 7, 8 and
3. After you have entered this combination, the purge numeric value will be reseted to 0000.
That's it...
Solution no. 3. (for printers with numeric keypad):
Resetting purge counter on MFC620CN/420CN/410CN/210C and FAX2440C:
1. Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode.
2. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6. Press the 9 key twice to return to the standby state.
Jan 28, 2011 | Brother DCP-110C All-In-One InkJet Printer
my canon pixma mp130 is coming up the waste ink absorber is almost full , how do i fix this , can i do it myself?
Two possibilities of solving this by yourself.
First solution: Clean the absorber pads
Look inside the printer, while the ink cartridge seated on the right side of the printer, under the ink cartridge is two absorber pads. Open the cartridge cover, to position the cartridge carrier in the middle. Leaving the right portion open and expose the absorber pads. Lift it up using a tweezer. Now clean this pads on a running water. And when its clean return it back to its place. Close the cover.
Second solution: Reset the Printer after cleaning the absorber pads.
These are the steps to reset your printer and clear all the errors including ink absorber full.
1. Turn on the printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Turn off the printer
Do this as many times until it fully reset the printer
Please give this solution a 4 thumbs up to help me improve my ratings.
Thank you for using Fixya.
Sep 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
xerox c20 copies always come out reduced by 50%
Give this a try.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'System Admin Tools' is selected, and then press the [Enter] button.
  3. If the System Admin Tools has been passcode protected, 'Enter Passcode' will be displayed. Enter the passcode, and then press the [Enter] button. If the passcode is unknown, or has been forgotten, contact your System Administrator.
    If the System Admin Tools has not been passcode protected, 'Passcode Protect' will be displayed. Continue with step 4.
    NOTE: If the Enter button is pressed, 'Passcode Protect (No)' will be displayed. Press the Menu / Exit button to return to the previous screen, and then continue with step 4.
  4. Press the [Left] or [Right] arrow button until [Clear Memory] is displayed, and then press the [Enter] button.
  5. Press the [Left] or [Right] arrow button until [System Data] is displayed, and then press the [Enter] button. All data and settings will be cleared from memory.
  6. Press the [Stop] button to return to the Standby mode.
When you do this you will have to go in and change the power save mode back to where ever you had it set.
Mar 24, 2010 | Xerox CopyCentre C20 Black and White...
What do I do when it says that ....The Waste Ink absorber is almost full?
1)Enter SERVICE MODE by pressing MENU-SCAN-COPY-SCAN
2)Enter NVRAM by pressing < or> then OK
3)Set ABS-M to 0
4)OK
Feb 12, 2010 | Canon PIXMA MP130 All-In-One InkJet...
1,956 people viewed this tip
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
