Tip & How-To about Philips CDR870 CD Recorder
Philips CDR870
I think there are several other possible solutions for the Philips CDR870 which will make it record more reliably, although using the "proper" Music Disc and cleaning the laser lens with an appropriate lens cleaning CD, seem to be the best ideas. Also, try wiping the blank or partially blank CD using a lintless microfiber cloth from the center outward to remove smudges and fingerprints. Several "failed" discs miraculously recorded after wiping.
If you're willing to "go under the hood", (you;ll need a #10 Torx screwdiver to remove the cover screws), you might try gently vacuuming the inside of the unit, brushing components gently with a soft camel hair brush to dislodge any dust that has accumulated; then gently sucking it into the vacuum cleaner. Make sure you've disconnected power to the CDR870 first! Trying to reach the laser lens itself involves surgical like dis-assembly of the sub-chasis and technical skills way beyond those of the average techie. I strongly DO NOT advise it!
Another possible solution is to let the unit "warm up" for about a half hour prior to recording, this may "cook" some electronic parts, and maybe change an internal condition to reduce the "OPCFAIL" problem.
You might also try cycling through "Input Source" by repeatedly toggling the Input Button (19) from DIG COAXIAL - DIG OPTICAL - ANALOG. Sometimes this allows the electronics to "wake up". It also may help to be playing an actual input signal into the unit while trying this.
I, too, have had frustrations with the unit using several brands of consumer and professional grade CD's. Occasionally, I have been successful in getting the unit to record music onto CD-ROM Data Discs when it's not supposed to. I have recorded onto Maxell, Sony, TDK and Discmakers (professional) blanks with varying results. FYI Radio Shack now stocks Verbatim brand discs for Music Recording (about $10 for 25 pack). Make sure CD Recordable Discs say "Music" or "Digital Audio" on the outside wrappings. I am a professional recording engineer, and now plan to see if the manufacturer, Philips Consumer Electronics in KY, can help.
Good Luck with this problem, I'll keep watching this site for other solutions.
Philips CDR870 CD Recorder Logo
imei 355376042089636 how code unlock
I think there are several other possible solutions for the Philips CDR870 which will make it record more reliably, although using the "proper" Music Disc and cleaning the laser lens (try some denatured alcohol on a cotton swab; then dry the lens with the other end) seem to be the best ideas. Also, if you're willing to "go inside", try gently vacuuming the inside of the unit to remove possible dust problems. Turn the power off first!
Another possible solution is to let the unit "warm up" for about a half hour prior to recording, this changes some parameter in the unit to reduce the "OPCFAIL" problem. You might also try cycling through "Input Source" by repeatedly toggling the Input Button (19) from DIG COAXIAL - DIG OPTICAL - ANALOG. Sometimes this allows the electronics to "wake up". It also may help to be playing an actual input signal into the unit while trying this. I too have had frustrations with the unit using several brands of consumer and professional grade CD's. Occasionally, I have been successful in getting the unit to record music onto CD-ROM Data Discs when it's not supposed to. I have recorded onto Maxell, Sony, TDK and Discmakers (professional) blanks with varying results. FYI Radio Shack now stocks Verbatim brand discs for Music Recording (about $10 for 25 pack). Make sure it says "Digital Audio" on the outside wrappings. I am a professional recording engineer, and now plan to see if the manufacturer can help. One more idea, cleaning the blank disk with microfiber cloth has also helped. Good Luck with this problem, I'll keep watching this site for other solutions.
Dec 23, 2012 | Nokia E63 Cell Phone
operating manual for cdr870
You may download a copy of the manual here.
Jul 06, 2012 | Philips CDR870 CD Recorder
replace the remote control
the only way are try it
ask the store if not works posible for refund
Mar 12, 2010 | Philips CDR870 CD Recorder
Philips CD recorder CDR870 not recording
Consumer CD recorders require CD-Audio or CD-Music blank CD's to record.
May 16, 2009 | Philips CDR870 CD Recorder
1,266 people viewed this tip
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
