Tip & How-To about Waring WMK300 Professional Belgian Waffle Maker
Permanently fix the waffle maker when it breaks in the back swivel which makes the wafflle top lid not open or the entire maker fall out.
Carefully drill a tiny hole in the center of the back plastic part.  Then drill a 1/4 inch hold centered on the first drill hole.  Put a 1/4/ threaded rod through the hole with a locking bolt on each side. But extra threaded bolt with a hacksaw.  Tighten bolts to just touch plastic.  See picture attached for solution.  When drilling hold be careful not to tough the plastic coated wire bundle.
Waring WMK300 Professional Belgian Waffle Maker Logo
i took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
manual floor shifter fell about 6 inches,91 capri
You need to take out the center plastic console around the shifter. With the shifter raised up into its correct position, drill a hole through the metal near the shfiter, and continue the hole through the shifter housing. Screw a sheet metail screw through the hole to hole the shifter into position. Do this in several places, and the screws should be a permanent fix. Good luck...Chris
Oct 11, 2012 | 1991 Mercury Capri
How do you install wall mount mailbox into brick house?
Make a new hole in the wall; the old one will be covered by the box. Depends to some extent on what the wall is made of, though. Can you drive a screw in and get it to hold, or do you need to use a plastic wall anchor?
If you're happy with the old location, start one screw in one of the old holes to begin with, just to hold the box in place temporarily. Level the mailbox, and mark the hole location of the other hole on the wall with a marker. Then swing the box out of the way, or take it down, drill a pilot hole for the other hole's screw. If required, insert a plastic wall anchor there, suitable for the screw you're using, then reposition the mailbox and insert screws.
If it's a masonry wall you'll need a masonry bit to drill the holes, and you'll have to be careful to line them up well. In that case, you might be just as well off back up the inside of the mailbox with a block of wood and drilling a new hole in the back of the mailbox to line up with the old hole. Just measure carefully, and use a center punch or nail set to make a dimple before trying to drill a hole in the metal.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 09, 2009 | Fulton Corporation Fulton 700m Wall Mount...
A dvd is stuck in my Chrysler town and country multi disk dvd/ cd player. How do I remove it?
Look around the face plate for a very small hole...use a straightened paperclip or equivalent and press in a few inches...its a manuel door release and you should gain access to at least the loading tray.
Apr 24, 2009 | 2005 Chrysler Town & Country
1,387 people viewed this tip
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
