Tip & How-To about Nikon Coolpix S4000 Digital Camera
Get more out of S4000
ISO
Set ISO Setting to FIXED RANGE and set the range to 80-400. The camera produces noise at HIGH ISO setting.
NIGHT SHOTS
Get a small Tripod and you can take wonderful night time shots of city-scapes. Use a tripod and set the camera White Balance to Incandes. Make sure the FLASH is Off Set the Exposure Comp. to -2. Set the self timer and then frame and press the shutter and back away. Some exposures can be 1 second long so a tripod is not optional. Small plastic Joby ones work. If you are holding the camera during the shot it will move with you. A self timer is used to take the photo after you are not touching it.
When you use the flash set the White Balance to Flash (Unless you are outside on a sunny day. then use daylight)
I do NOT recommend using Auto Flash. Set the flash to OFF or turn it to SINGLE BOLT for fill.
When you want to photograph people outside in the sun set the White Balance to Daylight. On sunny days use the Fill Flash (Single Bolt) to fill faces better. Yes good photographers use flash in the direct sun. When cloudy are in shade turn flash off. If the subject has a bright background get close to them and have the flash on.
This camera makes red eye. In most cases when you are taking a photo of people in low light, when the flash supplies most of the light, you will get horrible red eye. You have to edit these later to remove the red eye.
Nikon Coolpix S4000 Digital Camera Logo
when taking pictures at night, i find that its not that sharp and clear. that goes for the video shots as well. how do i rectify this problem. changing the modes doesn't very much. shots during the day is clear.
Night shots without flash will cause your camera to use a slower shutter speed. This can cause camera shake. To avoid this, put your camera on a tripod. Also, you can raise the ISO to a higher setting...however, too high and you'll get more digital noise in the picture.
Nov 04, 2010 | Cameras
The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
Night shoot and Indoor photo quality is not good with Fuji S5700
Your Sony camera must be more noise-free at high Iso settings than the S5700. As you view your shots on the camera, press the button with the square and the +/- symbol in it. Now you can see what Iso setting the pic was taken at. The 400, 800 and 1600 settings are all noisy on this camera. The only solution is to use a tripod with long shutter time and Iso 200 or less.
Apr 01, 2009 | Fuji FinePix S5700 Digital Camera
actions shots are blured
The various solutions include:
try to set focus range (settings), to infinity or to an approximate distance to the object you need to take a photo of as sometimes the automatic setting does not always do a godd job at focusing , or look at the lens when it is on if its got grease use a wet camera lens cleaning kit (someone touched the glass of the lens ) a s grease makesa it hard for the camera to focus , hence blurrig or go into your options and lower the iso mode or take it off night node if any as the iso mode leads to high exposure time which means any light that changes would record as a smear hence blurring or use flash.
Nov 14, 2008 | Cameras
Night shots
Try upping the asa number for night shots to aminimum of 400 and also the built in flash is really only good for about 15 ft of quality exposure. regrettably the cure for quality shots is the sb600 or if budget allows the sb800 flash with 15 min rechargable batteries. cures a multitude of problems out to about 45 yards.
Oct 12, 2007 | Nikon D70s Digital Camera
2,970 people viewed this tip
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
