Tip & How-To about Computers & Internet
PC Quickies
If your computer boots up really slow then u can change that. click on the START menu and Look for "Run." Type in "msconfig," and turn off running processes for "Startup." You will notice a 30 percent increase in boot time. ^_^
Computers & Internet Logo
vista only runs in safe mode
1. Press the Start button.
2.
Type msconfig in Start menu or click 'run' and type msconfig.
3.
Open the program. (Click msconfig icon if it doesn't open automatically)
4.
Also, open the command box. Click Start > run > and type cmd.exe and open. (If the above method does not work, using "msconfig", your "System Configuration Utility" program should open on your screen.
5. Click on the "General" tab on the utility program. Select the "Normal Startup" option. Click "Apply" and "Ok" to confirm the change back to normal mode.
6.
Follow the on-screen prompts to restart the computer. Your computer should reboot normally.
7. IF
this doesn't work: Click on the "Boot" tab in " msconfig" > the "Safe boot" option should be unchecked.
IF that doesn't work, go to "msconfig" again and click the Startup tab. Disable all startup programs or, if you know which one is causing the problem, just a single program.
Hope this helps! Godspeed
Feb 06, 2014 | E-Machines Computers & Internet
there is a listing available somewhere in Windows wherein you can "quick launch" a program to have it mostly loaded when first turning on the computer ( or have the program deleted from such listing). I can't find the program which gives this listing. I'm using Windows XP
A program can not be 'mostly [or partly] loaded' actually. You can go into the program's settings though and see if there's a way for it to 'Run on Startup', which would load the program when your computer boots up. The only problem with this is that it can slow your computer down and make it take longer to boot up.
Aug 21, 2011 | Computers & Internet
my HP laptop (Pavilion) is running very slow. I'm afraid to download the ''TV Specials'' we see advertised. Thx, Ray
download 'ccleaner' from filehippo.com & run it & remember when u run it, only check the temporary files,recycle bin,recent documents....
this might speed up ur notebook...
If you are using XP or Vista, you have this. You can access the boot menu by loading your MSCONFIG. During the boot up your computer issues a time out to find new hardware and software. You can short this time to boost your startup speed.
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility, click either BOOT tab.
5. In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Jul 09, 2010 | HP Pavilion dv6000z Notebook
computer boot screen slow?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
2. Click Run
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
hp doesn't start. Always open xp window saying gathering info Please wait while windows configures scan. Installed cd with no problem.
As soon as you start rebooting your computer, hit F8 over and over again until you get into a boot menu. Pick "Safe Mode."
It should boot. This is a temporary fix.
When you're in, click Start, then Run. Type in "msconfig" without the quotes. Hit Enter.
A new window pops up. Click on the Startup tab. Find a file called hpqtra08.exe and undo the checkbox. Hit Apply and OK. msconfig will ask you if you want to restart with the changes; you do.
Your computer should boot normally. When it does, msconfig will ask you if you want that menu to appear next time you boot; you do not.
Dec 05, 2008 | Computers & Internet
277 people viewed this tip
David Payne
David Payne
