Tip & How-To about Pioneer NS-DV88 System
How to configure 'Video 1' input to use Digital Optical connection
Connect the optical cable to the DIGITAL OPT(ical) IN connection.
Press the purple 'VIDEO' button on the remote until 'VIDEO 1' appears on the display.
Press the SYSTEM MENU button (to the right of the DVD play, pause, stop buttons).
'VIDEO1 INPUT' flashes on display.
Press ENTER
'INPUT ANALOG?' (the default) flashes on display.
Press right arrow (to right of ENTER)
'INPUT OPTICAL?' flashes on display.
Press ENTER
'INPUT OPTICAL' displays briefly, then
'VIDEO1 OPT' displays.
You are done. Selecting VIDEO 1 in future displays 'VIDEO1 OPT' instead of 'VIDEO 1'.
Pioneer NS-DV88 System Logo
No sound using optical cable connected to LG smart tv 60LN5600
Your receiver has 2 optical inputs. If you plugged in the cable to Input 1, you can select the "CD-R" Input on the receiver. Then use the "Signal Select" button to select Optical 1 (O1).
You can also use the "Input Select" buttons on the remote until the receiver says "Digital". Then use the "Signal Select" button to select Analog (A), Coaxial 1 (C1), Optical 1 (O1), or Optical 2 (O2).
Mar 08, 2015 | Pioneer VSX-820-K Home Theater Receiver
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
Connect Apple tv to Philips LX700
OPTION 1 (using remote):
Press the system key on the remote,
find the digital input option,
choose optical,
finish!
OPTION2: (Using LX700 button)
"program" button on the front panel for 5 seconds,then press LEFT or RIGHT button to choose DIGITAL INPUT,and Press "program" button again,then change coaxial to optical by rotating VOLUMN control on the front panel. then just confirm by pressing the "program" button again and wait for 5 sec to quit menu. Now switch OFF and switch ON receiver again.
Now make sure the source id DISC IN (ie., digital input ).
Your LX700 should be picking up optical signal!!
It worked for me and i hope it works for you to as well.
-SASi (ssasi2000@gmail.com).
Dec 15, 2012 | Philips LX700 System
how to get sound with optical cable connected to apple tv
hi,
connect the optical output of ur tv to the optical input of AVR. select the AVR remote's sliding switch to audio
1. press system setup button
2. using down arrow select digital in assignment
3. then select optical by right and left arrow
4. select it as tv by up and down arrow
5. press enter.
ok
Dec 21, 2010 | Denon AVR-485 Receiver
Digital/Optical Question
It's a pain in the butt getting the system set up to use the TOSlink from your PC.
Try this:
1. Hit the DVD button.
2. Use MODE/SET to get to DVD/OPT
3. Turn DSP off.
4. Use the TEST/SETUP button to make sure your speakers all work
5. Screw with your sound card!
Oct 14, 2006 | KLH R5100 Receiver
1,508 people viewed this tip
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
