Tip & How-To about Jacuzzi Whirlpool Bath AMH Spa Jet Nozzle White 1834940
AMH nozzle falls out repair.
If you cannot find a replacement as they have been discontinued. Try this. Remove the retaining ring and gasket. Take a empty 20oz generic water bottle such as Walmart or Ozarka. A thin plastic bottle. Cut the top out so it will allow the nozzle to fit very snug through the hole. Then trim about 3/8" to 1/2" more material off the bottle. You end up with a V shaped piece. Put the nozzle through the hole and add the gasket and Retainer ring. The plastic makes up the space where the nozzle wore thin. Once replaced in the tub it will still be able to rotate.
Jacuzzi Whirlpool Bath AMH Spa Jet Nozzle White 1834940 Logo
where is the thermostat on a 2002 sable?
Try this:
3.0L DOHC Engine
  1. Drain the coolant until the level of the coolant is below the level of the thermostat.
  2. Raise the vehicle and support it with jackstands.
  3. Disconnect the lower radiator hose from the water inlet connection.
  4. Unfasten the two water inlet connection retaining bolts and remove the water inlet connection.
  5. Remove the O-ring seal and thermostat from the water inlet connection. Inspect the O-ring for damage and replace as necessary.
To install:
  1. Clean the water inlet connection mating surfaces.
  2. Install the O-ring, thermostat and the water inlet connection. Refer to the accompanying illustration If you can-t remember how the O-ring and thermostat are positioned.
  3. Install the water inlet connection assembly retainers and tighten them to 71-106 inch lbs. (8-12 Nm).
  4. Connect the lower radiator hose to the water inlet connection.
  5. Fill the engine with coolant, start the engine and check for leaks.
  6. Stop the engine and top off the coolant recovery reservoir as necessary.
    Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines
3.0L OHV Engine
  2. Disconnect the upper radiator hose from the water hose connection.
  3. Unfasten the three water inlet connection retaining bolts and remove the water hose connection.
  4. Remove the gasket and thermostat from the water hose connection. Discard the gasket.
To install:
    NOTE The jiggle valve on the thermostat must be in the up position.
  2. Place the thermostat in the water hose connection making sure the thermostat jiggle valve is facing up.
  3. Install the new gasket and place the water hose connection assembly into position.
  4. Install the water hose connection assembly retainers and tighten them to 89-124 inch lbs. (10-14 Nm).
  5. Connect the upper radiator hose to the water hose connection.
  6. Fill the engine with coolant, start the engine and check for leaks.
  7. Stop the engine and top off the coolant recovery reservoir as necessary.
    Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
    Fig. Remove the upper radiator hose from the water outlet
    Fig. Remove the water outlet retaining bolts and . . .
    Fig. . . . remove the outlet from the engine
    Fig. Remove the thermostat from the water outlet
    Fig. Inspect the water outlet connection for cracks or damage
    Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
    Fig. . . . the engine before installing a new gasket
    Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
Jan 19, 2011 | 2001 Mercury Sable
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the part in the state of washington?
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
how do i change my fuel pump on my tahoe
this requires droping the gas tank out of the vehicle. once the gas tank is out turn the retaining ring and remove the fuel pump/sending unit from the tank and replace. most aftermarket pumps come with a diffrent plug and require some rewiring
Feb 13, 2010 | 2002 Chevrolet Tahoe
I have a Porcher one-piece toilet with a bad gasket. How do I take it apart and replace the gasket?
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
Jan 05, 2010 | Porcher 40050 Classic Elongated Toilet...
1,088 people viewed this tip
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
