Tip & How-To about LG 50PC3D 50 in. Plasma Television
POWER SUPPLY CAPACITORS
Look on ebay for power supply capacitor kit for your model. Range from $20 to $30..some even have soldering irons. Replace all caps paying attention to polarity. This will clear lots of sets that don't power up.
LG 50PC3D 50 in. Plasma Television Logo
Won't power on
Chances are it is the Power Supply. It is a Megmeet MLT386X which is hard to find, but sometimes IS available on ebay. There are places that will repair the old one advertising on ebay as well. If you remove the covers running across the heat sinks and see that the capacitors are bulging, the repairs are within the capability of anyone who knows how to use a soldering iron.
If you are handy with a soldering iron, LCDalternatives sells a kit with ALL electrolytic capacitors prone to fail for $15.95 plus shipping. I bought the kit and fixed mine. It took a couple of hours to unsolder and replace the capacitors. Powered up and has run for last two years with no problems.
Mar 04, 2014 | Akai LCT3701AD 37 in. LCD Television
wont turn on when u press on off button it just goes click click clickc
Go to EBAY and look up a capacitor repair kit for your model kit. They cost $20 to $30. This is to fix the power supply board which is the middle board. Be sure to note polarity of the capacitors you replace. There is a positive and a negative on them and that must be observed. Use a magic marker and mark the top of each cap as you replace it. Replace all caps supplied in the kit even if old ones don't look puffed out. This should fix your power supply. I did this on a friend's set over a year ago and the power supply is still ok.
Dec 11, 2013 | LG 50PC3D 50 in. Plasma Television
my Samsung flat screen tv won't turn on and it keeps clicking - it keeps trying to turn on but then starts clicking again.
There's a couple transistors on the Power Supply board that are probably bad. On mine, the solder joint was bad on the bottom side of the board that pointed me at those transistors in particular. Part number is FQPF9N50C. Also, you could get a refurb or new power supply board of ebay or send your board in for service (also on ebay).Or there's a "repair kit" you can get that contains 4 transistors and a couple caps I think. If you are an electronics junky and like soldering stuff, that would be the way to go... I just ordered the two transistors off ebay for like $6.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320632712822
http://cgi.ebay.com/Samsung-HP-T4254-Internal-Replacement-Circuit-Board-/230575679230?pt=LH_DefaultDomain_0&hash=item35af61a6fe
http://cgi.ebay.com/REBUILD-YOUR-SAMSUNG-BN44-00161A-Power-Supply-/200513469692?pt=LH_DefaultDomain_0&hash=item2eaf88bcfc
Jan 29, 2011 | Samsung HP-T4254 42 in. Plasma Television
How do I obtain and replace the C3 capacitor on the clock board of a Model SCE30600 Range?
C3 capacitor rated for 68 µF- 35 Volts the closest radial capacitor from RadioShack is P/N 272-1015 (47µF-40 Volts). Pay attention to the position of the "white arrow" on the capacitor when replace. A little patience, a soldering iron and less than $1.50. Your range will be as good as new.Bonne Chance!
Jul 08, 2009 | Jenn-Air SCE30600 Slide-In Electric...
5,376 people viewed this tip
Computer Repairing
Computer Repairing
