Tip & How-To about Jenn-Air JFC2087HRS Side by Side Refrigerator
New Jenn-air refrigerator, Model #JFC2087HRS, water filters do not work correctly. Modify them.
The new Jenn-air refrigerator, model #JFC2087HRS, water filters (UKF8001) do not work correctly. Water flow is slow. I have called the manufacturer but cannot get any help from them. They insist they work fine. I have tried several of the new ones. The problem seems to be that the small ramps on the new water filters are not tall enough to push the small plungers sufficiently into the water dispenser. I have added a small piece of plastic (glued) to the ramps on the water filter in order for them to work better, but not as good as old ones worked (UKF8001AXX). The next best thing is to buy the old filters if you can find them.
Jenn-Air JFC2087HRS Side by Side Refrigerator Logo
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the filter three times with the filter recommended by the manufacturer and have replaced the dual flow valve in back of refrigerator without success. When I remove the filter and install the bypass filter cover, water flow comes out with a good deal of pressure and no water hammer. Going back and re-instaling the water filter causes the problem to resurface.
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
slow water pressure and buzzing sound on fridge with new filter
Have you tried removing filter and reinstalling. Try that. Also sometimes you just get bad filters. Sounds like the bypass on filter housing not getting depressed all the way
Aug 18, 2012 | Refrigerators
My Jennair JFC2087HRS suddenly stopped making ice. I already replaced the filter but still nothing. Now what?
More than likely the ice maker has gone out. The part nunber for that is going to be D7824706Q
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 26, 2012 | Jenn-Air JFC2087HRS Side by Side...
water constantly drips from the dispenser and also water leaks at the left side bottom of the refrigerator
replace the filter and inlet valve of water.because of that only water is coming continously
Jun 11, 2010 | Jenn-Air JFC2087HRS Side by Side...
2,597 people viewed this tip
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
