Tip & How-To about Building Materials
Install a new hatch on your boat
Replacing old and damaged hatches on your boat is not a difficult or time consuming task. You will only need a few tools to replace the hatch. You will need some starboard (poly-sheets), screws, hinges, a drill, a saw, a screw driver, sealant and a sander.
Using the old hatch cover as a guide draw an outline on the starboard for your new hatch cover. Then using a saw and a guide cut out the hatch covers and sand the corners down so they aren't sharp and to round the edges all the way around.
If you need to add a finger hole to lift the hatch, measure and mark the place where you want to add the hole. Using a hole saw drill out the hole and sand out the inside and edges to make sure there are no sharp or jutting edges.
Go to the boat and using epoxy or an equivalent sealant to fill the old screw holes. Wait for the sealant to cure before moving on to the next step.
Lay the hatch cover over the hole on the boat and align the hinge and draw in where the screws go. Take your drill and make a hole for the screws to go in. fill the holes with sealant and screw the screws into the holes through the hinge. If there is any sealant overflow wipe it up carefully with a cloth. On the other side of the hinge repeat the previous steps being careful not to drill all the way through.
Once you have attached both of the hinges you are all ready to go!
Happy sailing!
Building Materials Logo
where can I find replacement parts for my boat's hatches?
There are lots of sites like ebay that sell all sorts of replacement parts for boat hatches, you can check out this site for parts too. http://www.boatoutfitters.com/replacement-boat-parts.html
Sep 10, 2013 | Building Materials
What is a hatch? Are they only on boats?
A hatch is essentially a trap door, usually found on boats in the floor of the deck. When classified as a trapdoor you can find them on any structure like a trapdoor on a stage.
Long load, can't shut hatch, constant beeping.
Hi the only way of doing this is you know the catch on the lid that locks onto the boot floor when you shut the boot. Well if you use a screw driver and push the lock round as though the latch would when you shut the hatch.
I mean on the hatch not the bottom bit onthe car you can see on the hatch what locks onto the boot floor if you use a screw driver as if it was the lock itself then you can turn the catch so the hatch thinks its locked.
It sounds a bit confusing but hopefully you understand what im saying you can move it round with your finger also.
But remember when you have took the wood out to press the unlock boot button to reset the lock on the hatch not doing this will damage the mechanism on the hatch and will then need replacing.
Let me know if you need further assistance ok
Aug 17, 2009 | 2008 Lexus Rx 400h
Replacement hatch strut problem
It is better to have someone help you hold up the hatch (very heavy). Remove the old struts, then install the bottom of the strut first. While moving the hatch up or down align the pin and snap in place.
Apr 13, 2009 | 2005 Honda Odyssey
Rear Hatch
there will just be some press clip pins holding it in place if yoou dont see any visible screws holding it so insert a cloth covered flathead screwdriver or the fork tool made for this and carefully pry the panel away from the hatch lid.
May 25, 2008 | 2001 Volkswagen GTI
711 people viewed this tip
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
