Tip & How-To about Inverter KEB COMBIVERT F5
KEB COMBIVERT F5 - Standard communications connections
Here is an overview of the the items required to communicate with the KEB COMBIVERT F5.
***X4A and X6B connections require special cable from KEB. This is a 24Vdc connection and will damage your PC/inverter if the proper cables are not used.**
Inverter KEB COMBIVERT F5 Logo
F5 KEB inverter nop problem
If using bus communications (Can, ProFi, Mod, ext), there may be a communications command (Software signal) that is not being provided. Hardware and software enable signal required to obtain LS.
Possible that the terminal on the control card is bad due to miss connection or signals outside of the rated value.
Apr 01, 2014 | Inverter KEB COMBIVERT F5
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Feb 12, 2014 | Inverter KEB COMBIVERT F5
Hi i m using keb f5 and cannot access submenu to adjust speed and torque. I.e.Us, Lf... How do i access it ?
Hello!
What shall I do to communicate with a Combivert F5. I have tryed with different cables without success.
RPN/ Sweden
Oct 29, 2010 | Inverter KEB COMBIVERT F5
3,472 people viewed this tip
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
