Tip & How-To about Nintendo The Legend of Zelda: The Twilight Princess for GameCube
Hidden skill 3
If you are having diffuculties mastering the Back slice then you should slice on the second jump when Link rolls so side jump, role, slice.
Nintendo The Legend of Zelda: The Twilight Princess for GameCube Logo
Bizerba SE12 slicer with the auto slicing. When on manual it runs for 30 seconds and shuts off. Start it again right away, after 30 seconds it shuts off. Manual slice it does not shut off Suggestions?
turn up auto operation time (knob on side) not thickness knob to a time more acceptable to you (or it can be malfunctioning too) just by noting auto slice mode tells you it runs on a timer , as it auto advances product to make even thickness slices each time
Aug 13, 2016 | Kitchen Appliances - Others
when I push in my clutch my truck does not role on a decline at all is this normal also it does not roll back when clutch is fully engaged
This would indicate a clutch that is not fully releasing ,this could be caused by a weak clutch master cylinder or slave cylinder. The vehicle should role when the clutch is depressed and on a hill. But i would also verify that with the trans in nuetral the truck does roll, if not this would indicate possibly a sticking park brake or rear brakes that are to tight. Thankyou RJ
May 30, 2010 | 1998 Mazda Pickup
Gas tank will not open
There is a wire broken in between the door and door jam. Slice the black boot the holds all the wires "carefully". Mine was the large orange wire. Spiced back with solder and heatshrink tubing.
Apr 22, 2010 | 2006 Volkswagen Jetta
2000 mitsubishi galant and all four of my windows will not rolle
check fuses first check power at master switch drivers door see if windows work from passenger switchs may need a master switch
Jun 04, 2009 | 2000 Mitsubishi Galant
960 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
