Tip & How-To about RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE
What's the function of LCD screen frame bracket?
There is a saying,what screen delay or don't have response may cause by lcd screen frame bracket. If there is something wrong with screen, how to check if the screen or frame has damaged? My iPhone 4s screen is alway stiff, I don't known if I should replacement a new screen replacement. Then this afternoon, I find some views about the screen frame bracket on the Internet. What's the function of cell phone LCD screen frame bracket .
Like this LCD screen frame bracket for iPhone 4s
RIM BLACKBERRY TORCH 9800 TOUCH SCREEN DIGITIZER with LENS COVER REPLACE Logo
lcd replace
You should the installation instructions with the new lcd screen
Replacing a damaged laptop LCD screen can bring your laptop back to life.
You'll be able to access files you thought were lost and use the laptop just as you did before. And it's not as difficult as you might think.
Turn off the power, unplug the battery and all cables.
Eject the installed battery if you have one.
This will protect you against electric shock.
Find the small, round rubber screw covers and pry them off.
This will expose the small screws holding the LCD screen frame in place.
Depending on your laptop, these covers might be made of some other type of material.
Remove the frame by gently prying.
Locate the LCD screen's cable and power supply cords. Unplug them and remove any tape holding the screen in place.
Check the identify of the manufacturer on the back or side of the screen.
It may be different than your computer's manufacturer.
Since these screens look so similar, make sure you order an LCD screen that matches your manufacturer's model number, or else the new screen will not fit.
Plug in the new LCD screen, replace any tape holding the screen in place and replace the frame.
Don't pinch any wires as you press the frame back into place.
Screw the frame down and switch on the power to see if it works.
If it does, go ahead and replace the screw covers.
If it doesn't, remove the battery, the screws and the frame.
Check your connections.
If it still doesn't work, call your parts supplier and ask for assistance in getting another replacement LCD screen.
Hope this helps
http://www.laptopscreen.com/
watch video
Nov 04, 2012 | Computers & Internet
Screen is non-functional and irreparable
hope this helps
Sep 17, 2012 | Computers & Internet
The picture frame still scrolls pictures but the pictures are very dark and unable to be seen well. Is the frame ruined?
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Jun 10, 2011 | SmartParts (1DPFSP01) Digital Picture...
Action Shots
I don't know your model of camera but this seems to be, "shutter lag", a comment issue with digital cameras. Take a look at this digital camera article on the subject. Also you may find a delay when using the LCD screen for framing the shot.
Sep 12, 2005 | Olympus Camedia C-720 Ultra Zoom Digital...
1,303 people viewed this tip
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
