Tip & How-To about Kyocera FS-C5030N Led Printer
Toner Box full when its not - fault
Putting a small lump of bluetac on the inside of the door will push the waste toner collection box into the correct position and stop the empty the toner box fault.
As the toner box is not seating in the sensor correctly.
Kyocera FS-C5030N Led Printer Logo
I keep getting an error message stating to install a waste toner box and close all doors.
Printers usually have a waste collector where excess toner is collected. Obviously, yours needs to be changed.
Mar 07, 2016 | Konica Minolta Bizhub C452 Color Copier,...
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
what is the waste toner box
The collection box for waste toner. When making a copy or a print not all of the toner that is put on the drum gets used, during the cleaning stage of the process that very small amount of toner is removed and sent to the collection box. Depending on your make and model there is a scheduled image count that the box is replaced or emptied at. If you try to empty it yourself be careful!!! Toner is the finest dust you have ever seen and can become a large cloud in the air (landing all over the place) if not handled properly. And yes it will go through a vacuum cleaner bag and into the motor. Service techs have vacuums that are made specifically for toner.
Aug 14, 2014 | Kyocera Tk-362
How do you change out the black toner?
If you can not rotate the toners by using the DISPLAY MENU,
You can rotate them MANUALLY, using a flat head screwdriver or even a key for your car or front door.
Open Front Cover/Door of Printer
Remove Waste Toner Box
Where you see the side of the Blue Cartridge, look to the LEFT and locate a small rectangle with a circle inside it.
Push your car key or flat head screwdriver into this rectangle and the circle will push back and release the lock on the cartridge, holding in with one hand and turning cartridge with the other hand until you get the cartridge you want to replace.
Remove the screwdriver / car key and pull out the empty cartridge and replace with new one.
Replace Waste Toner Box, close front cover/door, switch on and the printer will rotate back itself to it's normally position...... JOB DONE
Jan 19, 2010 | Minolta magicolor 2300W Laser Printer
What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Oct 10, 2009 | Brother HL-4070CDW Printer
2,893 people viewed this tip
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
