Tip & How-To about Hardware & Accessories
Mending a tear in a poly tarp
Some holes in a poly tarp are able to be fixed easily while there will be other tears that might be grounds for tossing the tarp. For most small tears you can fix them yourself using some tarp repair tape and vinyl repair cement.
Before beginning gather up all your tools, a damp towel, a dry towel, utility knife or scissors, a role of tarp repair tape, a small jar of vinyl repair cement and a hair dryer.
You will want to find a clean place to lay out the tarp somewhere where there won't be any wind blowing your tarp around. If you do have to fix the tarp outside use weights or rocks to hold the sides down.
Find the hole or weak spot on the tarp and if there is any fraying use your scissors or utility knife to cut off the frays. If there are any bumps you will want to cut them out too.
After cutting off the frays you need to clean the area around the hole. The reason you need to clean it is because dust and dirt can make it difficult for the tape to stick. All you need is a little water and dish soap on a damp towel. Rub the solution onto the tarp at least six inches all the way around the rip, you can clean farther to be safe, but six inches should be enough.
Wipe off the soapy solution with fresh water and wipe dry the area with a clean dry towel. Repeat this cleaning for both sides of the tarp.
To close the tear, place your tarp repair tape over the hole and extend it out at least four inches on to the undamaged area. First cover the tear horizontally overlapping if you need more than one piece of tape. Once the tear is covered completely horizontally overlap the tape with a layer of tape vertically covering the hole and extending four inches on either side. Repeat for other side of the hole.
It is important that after you tape up the hole you need to let the tape sit for ten minutes to make sure that it has bonded properly. When you come back after ten minutes open your jar or vinyl repair cement and apply a generous amount of cement over the whole taped up area. To dry the cement grab your hair dryer and blow hot air on the cement until it is dry.
And there you have it a fixed tarp, granted not all holes can be fixed this way. But after its been fixed you can use it again like new.
Hardware & Accessories Logo
are some tarps stocked in walmart stores
just wander down to see if the size you want is in stock
Nov 10, 2015 | Warp Poly Coverall Plastic Sheeting / Size...
Can you sew up a hole in a polyester tarp?
The only tarps that can be sewn are canvas tarps. For your polyester one depending on the hole you will want to use tarp repair tape (not duct tape). The tape is really heavy duty and should hold up to regular wear and tear. You will want to clean around the hole with water and dry it well, this will ensure that the tape will stick well.
Feb 06, 2014 | Hardware & Accessories
Give some importance of cheap tarps?
It is amazing that how much of an impact a simple item such as a tarp can have on our world. In 2010 the earthquake in Haiti created a high demand of cheap tarps. And when someone suggested that temporary shelter may be the heavy duty tarp, people from all over the world responded.
Oct 22, 2012 | Blue Wave NS586 24x39 solar poly tarp
What's a footprint tarp?
It is a tarp that fits exactly under the footprint of your tent, but is an inch or two smaller. If you have a 10' x 10' tent, your tarp would be about 9'10" x 9'10". If you have a triangle-shaped tent, your tarp would be triangle-shaped.
It is smaller than the tent so rain (etc) does not dribble down the tent wall, land on the tarp, and pool under the tent.
Jul 30, 2012 | Camping, Backpacking & Hiking
How do you chnge a platen roller on a zebra 220xi
you have to open the left side door, louse the screw from the motor (botom one), take the belt, from the poly, lose both screws from the poly. Take the poly out. take the ring and the small poly out from the platen.
from the side of the printhead, take the Peel Tear Bar- front plate (take une screw from each side )
from the rigth site take the washer and the small polly.
Jun 12, 2010 | Zebra Printer 140-751-00000
860 people viewed this tip
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
