Tip & How-To about Keurig B31
Keurig B31 jammed up.~ come up with some tips
Thanks for the tip received that was actually not listed in the the Keurig's user manual.
This morning I encountered my slightly over one month (Dec 2013) old Keurig Mini B31 jammed up, I was only used 3 times so far...:( and feeling quite frustrated after wasted all 3 K-cups to try and find out what went wrong, initially thought it did not punch the hold properly, but still only a few drops of coffee came out from the brew, everything thing seems to work fine, it was just no hot water flowing down.
Tried to clean up K cup bottom needle with clip, but does not help, after browsing though fixya found that the top part needle also really need to clean up (not stated in the user manual), by using paper clips and finally it works again after all the dirt came out from the top part of hold puncher. My tips for people who did not use it daily /very often, they should:
  • Clean up the top needle by running through a cup of water to flow it through the ground coffee excess after each brew was completed, otherwise it will tend to dried up and choke up before you know it.
  • It help to shake it cup to have the top of the cup fill with some air, and it has less tendency to have the ground coffee in block up the top needle.
Hope this tips will help you to maintain a good cuppa!
Keurig B31 Logo
I plug in my Keurig and the "prime" button doesn't show up. What do I do?
Here is a tip that I wrote about how to registeryour Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
KeurigRegistration, User Manuals, Cleaning, and Troubleshooting heatman101
Aug 02, 2011 | Keurig B60 Coffee Maker
Can't seem to get the settings properly on my Keurig Help would be appreciated
Jul 10, 2011 | Keurig Platinum B70 Coffee Maker
I need date stamp on jpeg photo file. Date stamp is not working. How do I reset?
Thanks for the tip that was actually not listed in the the user manual.
Jan 26, 2011 | Canon PowerShot A620 Digital Camera
Had the keurig 1 year.. This morning no power on keurig why?
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Nov 07, 2010 | Keurig Ultra In Home Single Cup Brewer...
1,941 people viewed this tip
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
