Tip & How-To about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to bypass Windows XP login passwords from scratch.
1.Download isoburner and rwps.iso
2. Extract isoburner.zip to your desktop.
3. Run: "IsoBurner.exe"
4. Select: "Create bootable USB disk"
5. For "Source ISO image file", select: "rwps.iso" (which is the password reset files) Hit: Next
**With WinRAR installed on your computer, it will make that file appear as an archive, but the properties show it is a .iso)
6. Plug in the USB device you will dedicate as a Password Reset, and select it from the drop-down box. Then hit: Create
*Once you hit: Create, it will dedicate your flash drive as a password reset USB drive. You will have to completely format the USB if you decide to remove the files in the future (it takes a couple minutes)
7. After created and your USB is flashed, plug into your computer that you are locked out of.
8. Boot up and you will have to hit ESC / F2 / F4 (depending on type of computer) to open your computers boot options.
9. Select your USB device and hit: Enter and it will run the password reset.
10. Leave Step 1 and 2 alone, it will auto direct to the SAM and System files, which store all computer passwords and accounts.
11. In Step 3: Select which account you will like to reset the password for.
12. In Step 4: You can change your password to a different one, or leave it blank for no password, then hit Reset. When prompted the Messagebox, click OK, and then save the file wherever you'd like. (Suggested to leave where it directs to with the other password files)
13. Hit Exit, and restart your computer. Boot regularly, and there you go!
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip
Code:
Code:
http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
1,807 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
