Tip & How-To about Tools & Hardware - Others
Extending the life of your lift magnet
In a scrap yard or other places where lift magnets are used on a regular basis they are an essential part of daily routine. But it is also a tool that can easily be ruined, abused or broken if not taken care of properly.
A few simple tips will keep your lifting magnet up and running for longer and better.
When you are getting your magnet out over the piles that you are going to be picking up make sure that you don't power up the magnet until it is over the pile. This will ensure that the magnet doesn't pick up anything along the way to the pile. Picking up stray pieces to the pile could block the magnet and can keep you from getting a full load. When you turn on the magnet let it sit on for a few seconds allowing it to power up completely and get a maximum magnetism.
It might seem like a good idea to work with a group of small piles rather than one large pile, but when working with a magnet the opposite is true. By gathering up small piles into a single larger pile will make the job go much faster.
Only use your magnet for lifting, using it for any other purpose can break the magnet and can be very costly to replace. Using a lifting magnet as a skull-cracker or battering ram can cause pretty big damage. When you are using your lifting magnet use it with care and let it down onto a pile gently to avoid banging it up.
Every so often you should check the magnet and casing for loose or broken bolts and replace them right away. These bolts help to not only hold the magnet together but also to keep moisture from getting in and causing electric shock.
Keeping the magnet cool will not only help to keep the magnet in a good working condition, it will also make your magnet carry more. A cool magnet is able to carry much more than a hot magnet. If your magnet does begin to over heat don't use water to cool it down. Store the magnet somewhere dry and off the ground to keep it from building up moisture.
Proper care and maintenance will keep your magnet running for longer and better. Paying attention to how they are being used and keeping tabs on their state will help to keep you from needing to replace your lifting magnet or spending a lot of money on repairs.
Tools & Hardware - Others Logo
Dell dimension 9100 PC Desktop blue screen
Use ReginOut, All-In-One tool which contains all the essential features that are required to make your computer trouble-free. If you perform system optimization tasks on a regular basis, your computer will not behave abnormal and your data will be protected.
Dec 27, 2011 | Dell Dimension 9200 PC Desktop
how do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
What kinda things do i look for / maintenance on a daily/weekly basis to keep my 07 gsxr in good running condition?
hi bud there isint much you can do week to week other than put petrol in lol a good thing to have on the bike if ya can is a scott oiler a handy tool as it keeps your chain lubricated more regularily than normal oiling but the chain would be a monthly thing to keep doing as a good oiled chain is important for easy driving every year or 6 months depending on driving time your oil and filter need to be changed battery can be charged every 4 5 months if not used alot it will drain slowly with lights indicators and such so in the winter months charge or get your self a trickle charger will keep your battery alive if not been used just take battery out plug into trickle charger away ya go and plugs may need to be changed every year again driving dependent but as for regular routine stuff there isint much other than oil greasing with a good chain wax is best hope this ok
Feb 23, 2011 | 2007 Suzuki GSX-R 600
drivers window doesnt go up or down but you can still hear the motor
More than likely it's the regulator assembly. They are kind of a drag to replace. Most operate with a plastic band that has teeth that will mesch to a gear, and the teeth will break off.
Dec 22, 2009 | 1995 Honda Odyssey
nebulizers tips
Making asthma treatment a natural part of your child’s daily routine is important and does not have to be challenging. The following are just a few tips. Do the treatment(s) at the same time each day, so that your child comes to expect it as a regular part of the daily routine. Entertain your child with videos, music tapes, toys, coloring books, puzzles, looking at books, or reading to your child during treatment. You should put the mask on a favorite stuffed toy or doll first. Show how much fun the toy is having or how brave it is. Then, transfer the mask to your child.
Aug 27, 2008 | Drive Medical Replacement Battery Charger...
883 people viewed this tip
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
