Tip & How-To about Hand Tools
Using a Chalk Line To Mark Straight Lines
When working on walls for floors that have very large expanses of flat area, without a laser level it can be very difficult to mark long, straight and level lines. There is a very simple tool that many carpenters and construction workers favor over the laser level, it is the chalk line (or chalk box).
Using the chalk line is very simple, you lay the string down on the surface that you want to level. Many of the chalk lines have a hook like piece on the end to hook on to a nail or edge so you won't need a helper to hold it it place. When you reach the other side of the area you want to level, pull the string taut and pluck the string. This will transfer the chalk from the string to the surface.
If you are using a manual winding chalk line you will need to roll the string back into the box if you want to do another line. Some chalk boxes are automatic and will have a release that will wind the string back up like a tape measure. The reason that you need to rewind the strong after every line drawn is because you need to reload the strong with more chalk. Its like how when painting you need to reload the paint brush with more paint when it runs out.
The chalk inside the box can come in a few different colors that are used for differnet purposes. The most common color is blue, red is more permanent so its good for a line that needs to last for a day or more, and white is good for interior painting because it can wash off easily and doesn't bleed.
Hand Tools Logo
how to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
Mar 29, 2013 | YouTube Videos
adjusting the headlight on 2005 roadking
Hi Anonymous, the correct procedure for adjusting a head light is as follows:
1. Verify correct tire inflation.
2. Place motorcycle on a level floor or pavement in an area with minimal light.
3. Point the front of the motorcycle towards a screen or wall witch is 25 feet from the axle of the front wheel.
4. Draw a horizontal line that is exactly the same height above the floor as the floor is to the center of the head light.
5. Have a person whose weight is roughly the same as that of the principal rider sit on the motorcycle seat. The weight of the rider will compress the suspension slightly.
6. Stand the motorcycle upright with both tires resting on the floor and with the front wheel held in straight alignment pointing forward.
7. Turn the Ignition/Light Key Switch to Ignition. Set the Light Switch on the left handlebar to High Beam.
8. Check the light beam for proper height alignment. The center of the main beam of light should be even with the horizontal line on the screen or wall.
9. Check the light beam for proper lateral alignment. The main beam of light should directed straight ahead i.e. equal area of light to the right and left of center.
10. The headlamp adjustment can be performed without removing the chrome ring. If the headlamp alignment requires adjustment use slots in the headlamp chrome ring to insert phillips screw driver between headlamp housing and rubber gasket. Turn the vertical adjustment screw as necessary to align the headlamp vertically. Turn the horizontal adjustment screw to adjust the headlamp horizontally. Good luck.
Jul 24, 2012 | 2005 Harley Davidson FLHRCI Road King...
How do you adjust the headlight on my harley xr1200
Hi Schnauzersru, the correct procedure for adjusting a head light is as follows:
Aug 20, 2011 | Harley Davidson XR1200 Motorcycles
I am tiling my bathroom from a full strip out. The walls are plum and level all round but when I use the laserlevel, the line is out when I get back to the start corner. My builder has checked and double checked. Is it possible the laserplus needs calibration in some way?
If I understand which unit this is, it's not sold as a highly accurate instrument (advertised use is for hanging pictures). No numeric specifications were given for it's accuracy. And I don't think it is adjustable. Also, by using the level on each wall progressively you might be accumulating error manually.
You can easily measure the accuracy of your laser level by taking it to a room with one long wall (the bathroom is too small) Hold the laser against the wall at the left end of the room and make a mark nearby. Have a helper make a mark on the wall at the most distant point possible (at the right end of the room) Now put the laser near the mark your helper made at the height aligned with his mark. Now, back at the left end of the room have your helper measure the vertical distance between the laser beam and your first mark. This will measure double the level's error over the length of the wall. However, this test assumes that the beam coming out of the left side and the right side are perfectly co-linear. .
Aug 06, 2010 | Garden
966 people viewed this tip
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
