Tip & How-To about Garden
Rake your leaves to the tree lawn in no time!
When I was growing up it was always a family activity in the fall raking up the leaves in the yard. Over the years I have seen my parents try a whole slew of techniques for getting those pesky leaves from the yard to the tree lawn.
The technique explained in this tip will only work if you live in a city that does leaf pick up using a vacuum truck to pick up the leaves. If you have to bag your leaves then this technique will not be helpful.
The one way that they found to be the most efficient although a little physically exerting involved a few rakes and a large tarp. If you have a large yard you will want to get a few helpers.
Start by picking a place to layout the tarp. When the location has been selected start raking the leaves away from this spot so that you have a clear space to layout the tarp.
Once the tarp has been laid out rake the leaves on to the tarp. You can lift the sides of the tarp to move them in to the middle so you will have space for the rest of the leave in the yard. Continue raking the leaves into smaller piles and then add them to the pile on the tarp until the yard is clear.
When all or most of the leaves have been moved from the grass to the tarp you are ready to move this mountain to the tree lawn. Gather up two of the corners of the tarp and carefully not to lift the corners too high so that the leaves don't fall off the other end. Drag the tarp from the back yard or front yard to the tree lawn.
Line the edge of the tarp up with the edge of the tree lawn and lift the far side of the tarp up towards the tree lawn. Lift it like you are going to flip the tarp onto the tree lawn. This will make the leaf mountain flip on to the tree lawn and walla! the leaves are ready to be picked up or played in by your kids!
Garden Logo
how to care for ho useplant begonia rex?
Growing Requirements for Rex Begonia Plants Rex Begonias grow best in bright, indirect sunlight coming from an east or west window.
Fluorescent grow lights are also an excellent alternative to natural light for these plants,
and in many cases will intensify the foliage colors.
When potting, set the plant with the crown slightly above the soil line.
They should be planted in a porous, slightly acidic planting mix that contains some peat moss
and leaf mold. African Violet potting mixes work well for Rex Begonias.
Allow the top 1inch of soil to dry before watering, then water thoroughly.
Over watering can lead to root or crown rot! Wet foliage can cause problems with mildew.
Always use room temperature water when watering house plants.
House plants should never be allowed to stand in water for more than a few hours.
Painted-Leaf Begonia plants thrive with daytime temperatures of 70-75
and 60-65 at night. NEVER lower than 60!
They require a humidity level of at least 50 percent and appreciate periodic, light misting.
Provide additional humidity by setting the plants on shallow trays filled with moistened pebbles,
or a humidifier, especially during the winter months.
Feed actively growing plants in early spring and again in early summer with a slow-release plant food,
or every 2 weeks using a quarter strength dilution of a soluble, complete fertilizer (23-19-14).
Decrease feeding in early fall and stop altogether in the winter. Do not over-fertilize!
Your Begonia Rex may go dormant in the winter and possibly drop its leaves.
If this happens, continue to water sparingly until spring when new leaves will re-appear.
If your Rex is growing where it only gets light from one side ( a window sill),
turn the pot a quarter turn each week to maintain even growth.
Foliage color may fade under low light conditions. Consider using a grow light.
Remove any dead leaves and other debris around plant regularly.
Rex Begonias enjoy spending the summer in a shaded part of the garden.
Always be sure to check for insects and pests before bringing your plants back indoors!
Rex Begonias are susceptible to attacks from mealy bugs.
Aug 03, 2014 | Cycling
how do i get the leaves off of my steep metal roof
Buy a snow roof rake.They have poly propolene radial scoops on them they wont dammage roof. You can use it for snow as well. You wont need the latter. Mutch lighter as well.
Nov 28, 2012 | Cars & Trucks
I have a new graco cleo car seat. What weight and age does my baby have to be before I shoud face it forward in the car?
Group 0 Until the age of 12 months (13kg/28lbs), your child must always be in a rear-facing position. Group 0+ car seats move from a reclined to a seated position, whilst perfectly supporting your child's back.
Group 0+ Until the age of 12 months (13kg/28lbs), your child must always be in a rear-facing position. Group 0+ car seats move from a reclined to a seated position, while perfectly supporting your child's back.
Group 0+/1 Children are unique and grow at different paces so category 0+/1 seats are highly flexible to reflect this. Babies up to 9kg (19 lbs) can travel safely facing the rear. From 18kg (39lbs) the seat can be adjusted so they face forward, allowing you to spend more time face-to-face with your baby which is an important part of parent-child bonding.
return to top
Group 1/2/3 The car seats in this category grow with your child from 9 months to 12-years old (9-36kg/19-79 lbs) so they can remain comfortable and importantly, develop properly. This flexibility makes it the ideal car seat category for large families and grandparents with grandchildren of different ages.
Group 2/3 A child must have a car seat that is tailored to their weight, height and age until they are 12 years-old, or 36kg (79lbs). The group 2/3 category offers convertible seats for older children aged between 4 and 12 (15-36kg/33-79lbs), this means the car seat grows with your child.
Hope this helps, I have a graco for my 12 week old, this info is from the graco website
Bye for now
Aug 04, 2011 | Graco Baby Gear
who is in my back????????????????!
Are you asking "Who has your back?" or Who, will back you up no mater what, type of thing? Who has your back, Your family has your back, unconditional love, always there for you. They will help you to their ability, (if you do not or have not turned your back on them). This is what happens in a lot of family's. The child gets to an age (almost adult) and turns selfish, turns their back to the parents, claiming, "I'm hurt, you hurt me", "you will not let me be me", then through selfish acts, push the parents away with an "ATTITUDE". Then the parents, have to protect the teachings they gave the "child" as he/she was growing up. With this protection, they have to force the child out to "sink or swim", "learn for themselves", "make it or break it". In most cases the Young adult will now have to tell lies to find a new place to live. Then they build up too much pride to return to the parents and give an apology. Now, we have no communication, the child feels as if the parents, "no longer loves me" and turns further away. So, in this case, it is the child that must return and ask forgiveness, show the parents they have learned to be responsible. That the selfishness is gone, more giving, easier to talk to, more apt to listen. That they can handle their money, are not self centered. Once you do these things, return and show this through your actions, I will give my life for you, all I have is yours, the air I breath is yours, unconditional.
Jul 14, 2011 | Answer Racing Ion Motorcycle Jersey 2010
Love Marriage & Career
Try to talk agin with your parents, if necessary involve your parents's older family.. Try to listen the reason why they are not ready and listen with your heart... Believe me, if no parents permission your marriage is direct to nowhere! I know love is blind, but blindness should obey the mind logic way of thinking! Remember, your parents DID more than your boyfriend do, Your parents raised you till grow like this today... If you still want to get what you want, talk talk talk again with your parents. If you realized, just play the song from The Rolling Stone (You can't always Get what you want!) or Geoge Michael (Waiting For That Day!). Please note, God Bless Gate are in your parents permission. Trust Me! I've been there and Done that! GoodLuck!
May 27, 2009 | Computers & Internet
708 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
