Tip & How-To about Garden
Sharpening your garden pruning shears
Every so often you will find that your gardening shears just aren't up to snuff. This will usually be most prominent when it get really difficult to cut through even the weakest of branches. Cleaning and sharpening your pruning shears is very simple and can be done in a matter of minutes.
To start you have to make sure that your shears are clean. Its not difficult to clean them, you can use a cleaning solution like scrubbing bubbles to get the dirt off, you just spray them and wipe them off with a soft cloth. If there is a lot of dirt or rust on the blade you might need to use a wire brush or a piece of steal wool to get them clean.
When you are satisfied with how clean the shears are you will need to get a sharpening stone. Carefully using your thumb on the convex blade (the big side of the shear) of the shears find the beveled edge. This will tell you the angle that you should be using to run the stone along the edge at.
When you have identified the angle that you're going to use to sharpen at, take the stone in your dominant hand and in the other hold the shears open. Applying a little bit of pressure rub the stone in small circles. You don't want to over do it, just a few times should be enough to get the blade sharp again.
The beveled edge should be the only blade that needs to be sharpened. On the flip side of the balde you shouldn't need to sharpen because it should be flat. In the case that you run your finger along the flat side and you find a bump you can use your stone to just smooth it out.
When you are satified with how smooth the blade sides are you should put a little bit of oil into the joint of the blades and open and close the blades a few times to get the oil into the gears. And finally using a cloth wipe the oil up and spread it over the blades. Wiping the oil over the blades will help to keep them from getting rusty.
To make sure that are ready to use you can test them on a piece of shrubbery or you can just head back out to the garden and get to work!
Garden Logo
i can't start my echo leave blower - 4131H, should the choke be in the high position?
There really aren't any "choke" diagrams on your model. There ARE parts listings, but they don't list the orientation of the choke lever is start position. Try removing your air filter element . Then open the throttle all the way. This will allow you to view the choke plate on the carb itself and what it is doing.
Sep 09, 2011 | Garden
i have an acer aspire one notebook that constantly locks up, I have very few items that would take up memory but it randomly just locks up and i have to use the on/off switch to turn it off.
Some of the most frequent causes of lockups are
* Operating system has gotten corrupted over time. A repair install, not necessarily a format and reinstall, may clear this up. Look up on a search engine about how to do a repair install.
* Wonky video drivers - In Device Manager delete video drivers and let it autosense to reinstall.
* RAM chips that aren't up to snuff. You can run something like memtest to check them.
* Conflicting programs running. Shut down any unnecessary programs.
* And especially in laptops, overheating is one cause of lockups and restarts. Make sure vents aren't blocked or clogged by anything and that cooling fan(s) are running as they should. Don't rest the laptop on the carpet or on a pillow, this interferes with cooling. A cooling pad may be in order.
Aug 21, 2011 | Computers & Internet
I have replaced the batteries on my Gardenmate Dual Outlet Tap timer, and it is still not working. The system is only 12 months old, and I am unable to solve it. Can you please help me.
I reckon they're useless. New batteries still aren't powerful enough to drive the whirring gears of the timer inside (they only take AAA batteries).
I have the same problem as you, which has happenede on both timers I've bough...they usually give out after a month or so and nothing gets them going again,
Sadly a dreadful product, poor design and waste of money. Shame really as it could be so good to really "set and forget"
Feb 20, 2011 | Garden
my 5hp 22 inchsnow blower does not throw snow The auger seems to work but the impeller will not shoot the snow. Could it be that the belt needs to be replaced or is there another cause?
Could be the belt or more likely, a shear pin. I would lean toward a shear pin.
You don't mention the make so it is difficult to proceed.
Thanks for your interest today.
Jan 30, 2011 | Craftsman Garden
I have an ariens 824 snowblower that needs shear pins. How to replace. Where to purchase them. I live in Hyannis Ma. Nick
Most times when a shear bolt/pin shears, the outer ends fall off into the snow, the inner part of the bolt stays inside the auger shaft. You must rotate the auger/ribon to find the hole in the shaft that has the bolt left in, and then with a drift punch, drive the bolt out of the shaft. Depending on the amount of rust, rotation may be difficult. Depending on the shear bolt, finding the internal broken part may also be difficult, but you should see a 'fresh metal shear' of the broken bolt. You can purchase them on eBay or your local lawn & garden dealer should be able to get them.
Dec 22, 2009 | Ariens Garden
798 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
