Tip & How-To about Saws
Choosing the right hacksaw for your job
For every project that you want to work on, there will be a different set of tools that you will need to use. The hacksaw has different types of blades and frames that can be switched out for the different projects that you are working on.
There are three main kinds of blades that the hacksaw can use and each one has different benefits. The teeth on the hacksaw blade will range between 14 and 32 teeth per inch. The thicker the blade the fewer teeth there will be per inch on the blade. The types are regular, raker and wavy. Regular blades are good for soft metals that don't have a lot of metal and the teeth will be closed together touching and alternating left and right. The raker blade has teeth placed in sets of threes and are best used fro cutting through thick metals. The last kind of blade is called a wavy blade, on these ones the teeth are in a wave pattern that are great for making smooth cuts in hard thin metals.
When it comes to hacksaw frame types there are two types to look at the fixed frame and the adjustable frame. Fixed frames are only able to hold a blade of a single sized length of blade. The adjustable frame can hold different length blades typically between 10 and 12 inches. The blades that you will buy for a hacksaw will have holes on either end of the blade. These holes are used to attach and dettach the blades from the frame.
Whatever the blade that you are using make sure that when you are sawing through metal make sure that you go slow because rubbing metal on metal will generate a lot of heat and can spark. You can also ruin the blade on your if you are sawing too quickly.
Saws Logo
Are there different types of hacksaws?
They aren't really different types of hacksaws, they're more like variations of the traditional hacksaw. There is the panel hacksaw, junior hacksaw and the power hacksaw.
Jan 02, 2014 | Saws
whats the difference between a hacksaw and a panel hacksaw?
a panel hacksaw has no frame, so it is better for use in cutting sheet metal
Jan 28, 2013 | Saws
I had a dremel passed down to me but don't know what it is for. Please advise how I can make use of this tool.
http://www.dremel.com/en-us/projectsandcommunity/projects/Pages/default.aspx
this website is directly from dremel. It shows different projects, crafts, or hobbies you can use it for. It is a real simple tool to use, and also is very handy. You can obtain several types of bits for it ones for sanding, engrving, cutting all types of materials, and much much more. Hope this helps
Jan 23, 2011 | Dremel 395 Variable Speed Multipro Rotary...
Don't know how to change fuel filter on this one.
This one takes a special tool to un-clip the fuel line from the filter. Aso,If you can't get the clip to release, you wind up cutting the filter ends off with a hacksaw. The money you thought you saved, just went into an all day project,laying on your back.Unless you want to buy a special tool you only use once in awhile, let someone replace it that has one.
Oct 06, 2009 | 1998 Mercury Mountaineer
1 drain pipe with 2 traps
eyohe
Please read and understand these entire posts and collect all tools & materials before beginning this project.
Materials needed:
2 - PVC 1-1/2" compression x 1-1/2" female Schedule 40 solvent        weld trap adapters.
2 - 1 1/2"PVC-DWV ADJ P- traps (serviceable)
1 - PVC 1 1/2 X 1 1/2 X 1 1/2 sanitary Tee
1 - 90 degree PVC short turn elbow
1 - 4' piece of 1 1/2 PVC sched. 40 pipe
1 - 4oz can Oatey PVC Regular Clear Advanced Cement
1 - 4oz can Oatey PVC Clear Primer
1 - Small container plumbers putty (To be used as a gasket like bushing between the disposers basket strainer and the sinks surface)
Tools that are needed:
Safety glasses
Latex gloves
Hacksaw
Torpedo level
Measuring tape
Channel locking pliers
Sharpie type pen/marker
Old work rags to clean the edges of freshly cut PVC pipe of loose debris.
Old newspaper to protect your floor/work area and the floor of the sink base.
Any other tools listed with the disposal installation instructions.
Feb 19, 2009 | Plumbing
955 people viewed this tip
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
