Tip & How-To about Saws
Benefits of using a scroll saw
Some times there are woodworking projects that you will want to do that can be very difficult to do with a regular power saw. There are several big benefits to using a scroll saw over other saws due to its ease of use and control.
Lets say that you want to make a jigsaw puzzle, you could use a jigsaw saw that has to be mounted on a table because they are difficult to control or you could use a scroll saw that is a mounted saw to begin with. You will also find that a scroll saw allows for more control and has much less vibration than a jigsaw.
The cuts that a scroll saw make are so smooth that in most cases you won't need to sand down the edges. This is a really helpful feature when you are working on cutting difficult to get into angles and cutting inside a piece.
The ability to make an interal cut without having to start the cut from the edge of the piece of wood a huge advantage over most other saws. When you want to make a cut out all you have to do is drill a hole in the area you want to cut out, and then slide the blade through the hole and use the scroll saw to cut out the edges. There is also a foot pedal that you can use so that you can keep both hands on the piece so it doesn't run away when the blade starts moving.
Many power tools tend to be very loud, which lends themselves to the user working alone with earplugs of some other forms of hearing protection. The scross saw is a very quiet power tool that is perfect for you to teach your kids about the art of woodworking. And it is safe enough that they can use it to build their own model airplanes and artwork.
Saws Logo
What is Quarter-Sawn Lumber?
Quarter-sawing is a method of milling trees into lumber. Quarter-sawn lumber is highly sought after, particularly in certain species such as oak or maple, where look of the grain in the wood is accentuated by the method of cutting the tree. While rip-sawing is the most efficient (and common) method of milling, quarter-sawing is more difficult to cut but yields much more stable lumber. Because it is more difficult to cut and there is more waste, quarter-sawn lumber is considerably more expensive than rip-sawn material.
(taken from http://woodworking.about.com)
Feb 27, 2013 | Crafts & Hobbies
what is the 'throat' on the scroll saw?
the throat refers to the distance between the blade and the rear frame of the saw. this distance allows the woodworker to know how big a piece of wood can be cut by the saw. industrial scroll saws can have throats up to 30 inches
Jan 28, 2013 | Saws
i have a makita 7.25inch hypoid saw and cant get the field out of the housing. is there a trick?
I hope I can help you with this.
When I have disassembled power tools in my woodworking shop, I have found that all seals, baffles, etc. have to be removed before you can get the windings out. If it was overheated, it sometimes is difficult also. Be sure nothing inside the housing is holding it in first.
Hope this helps,
Handie Andie
Mar 28, 2011 | Makita 10 14 Circular Saw (With Electric...
circular saw engine question
it's important to choose a tool with a motor that is powerful enough to meet your needs. For example, a woodworker should choose a saw with enough power to cut through everything from wet lumber to dense hardwood. If the motor in the saw you select doesn't have enough power, the blade heats up and begins to dull. In addition to creating poor quality cuts, this can become a safety hazard if the blade starts to climb out and push the saw back towards the user. However, evaluating power from the motor ratings can be misleading. Amps indicate only the amount of electricity a motor draws, not the power it sends to the blade. Horsepower accounts for torque (rotational force), but not necessarily under working conditions. So be careful and ask the seller if this particular tool suits the work you want to be done.
Aug 27, 2008 | Bosch SR6R180 180 Grit 6" Disc 6/Pack Red...
728 people viewed this tip
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
