Tip & How-To about CDA Cooktops
CDA Oven not heating? How to replace a CDA fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Cooktops Logo
what does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
Apr 05, 2015 | Electrolux White Westinghouse Stove Range...
We set the ovens to bake, they click but do not heat up.
Could be the elements.if it is a fan oven the elements sit behind the rep late.first check the fuse box.then if the oven lights up it could only be the elements.they are easy to replace .you can buy the replacement units off eBay.you can also watch a tutorial on replacing them on YouTube.
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
Why won't our oven fan turn off? The oven has not been used and oven is cold.
Hello friend, thank you for your inquiry!
I understand that your fan is not turning off and the element reads "HE" on your Frigidaire range. It sounds like you could be having an issue within your control panel or wiring harness. It may not be communicating properly to your fan or element that it is shutting down. I would recommend having a technician come out to properly diagnose and repair your appliance. -Matt
Sep 01, 2014 | Frigidaire Ffes3025lw 30 Smooth Top...
Why is my oven not heating up?
My guess is the heating element has gone. Get online and search your domestic appliance web sites quoting the make / model / serial number etc and see what element is needed. If you are capable of good DIY and know how to isolate the cooker then its not a big job to replace. I've googled your model and the elements are readily available. You don't say where you are but the elements are readily available in UK for between 20 and 30$. I had a similar problem with my double oven and found a suitable height table, covered in news paper, slid the oven out of the unit, changed the element, all done in under an hour. If yours is under worktop then slide onto a piece of board on blocks.
Jul 17, 2014 | Smeg Cooktops
996 people viewed this tip
Top CDA Cooktops Experts
john h
ray gallant
Steven Lunnon
Are you a CDA Cooktop Expert? Answer questions, earn points and help others
