Tip & How-To about Battery Biz Computers & Internet
My computer won't keep time!
If your computer continues to lose time or doesn't keep the correct time, your CMOS battery might be bad. Try this, reset the time on your computer and check it 24 hrs later if it is off by more than a few minutes or hours then the CMOS battery is probably bad and needs replacing.The CMOS battery is just about the same as your watch battery and doesn't cost much but is tricky to replace if your not careful.
Computers & Internet Logo
Is my CMOS battery the problem to the time and date not automatically correcting itself, or is it something else?
The CMOS battery is the main cause of your time resetting. Although it usually resets further back. Double check your time setting in the operating system itself. If everything is correct then the source of the problem is more then likely the CMOS battery. Batteries are pretty cheap so not hard to replace. If it is a desktop computer (if you're comfortable with it) open up you computer and what looks similar to a watch battery and that is what you will need to replace.
Note* IF it is the CMOS/ BIOS battery it will only reset the time when you lose power to the computer or turn it off.
Oct 04, 2012 | Computers & Internet
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at "Windows" screen for about 45 seconds before going to press f1 to continue etc... Then takes forever to load a page to the internet... but once on, every things ok. Shutting down is a night mare.. takes a good 5 mins or so to completely close down and now it say "out of memory" at line..... more then one problem!!!
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
1,032 people viewed this tip
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
