Tip & How-To about Computers & Internet
Using a USB drive duplicator to make copies of a USB drive
There are times when you have to make multiple copies of the same information on many USB drives. If you are making a few copies like 2-3 then using the ports on your computer will be good enough to make the duplicates, but when it comes to make more duplicated you will want to get a duplicator.
Duplicators will range from around 1:7 (one USB copies to 7 USBs) all the way up to 1:100. These are perfect for corporations that need to give their employees many files and don't have a lot of time to make the duplicated one at a time.
Using a USB drive duplicator what you do is on the tower (or in the accompanying computer software if it is plugged into the computer) set the display to copy, usually there is an enter button that should take you the menu and arrows to help you move through the menu. When you have copy selected plug in the USB you want to duplicate in the port labeled source. And then plug the blank USB drives in to the other ports. Most systems have a green light that lights up when the drive is plugged in properly. When all the green lights are on and all the USB drives you want to duplicate are plugged in.
Hit the enter button and the device will start to work. On the display you will see a few things happening, it will say things like copying... and initializing, and the green lights will flash. When the finalization process is finished the display will tell you that it is safe to remove the USBs. And that's it you are done! It could take you days to do them by hand or just hours to duplicate hundreds of USBs using a duplicator.
Computers & Internet Logo
Files copied onto kingston dt1/16gb usb get garbled.
Many people don't realize this, but flash memory wearsout the more you delete and write files to it. How quickly it wears out willdepend on the specific flash drive. Like anything, there is a wide range ofquality in currently available flash memory-based drives. You can make a roughcorrelation with the cost/quality of the device (what you pay is what you get),but even that tends to change over time. Depending on usage and quality itcould be talking as short as months or as long as several years. In extremecases of misuse it could lasting as little as a few weeks.
Apr 18, 2012 | Computers & Internet
How long can a external hard drive be without electricity without loosing the information?
The newer hard drives can hold the data with no corruption for around a good ten years. If there is something that you want to save, make sure to have multiple copies. If your storing this hard drive make your to store it in an anti static bag.The location should be low humidity. If you're thinking of buying a hard drive for long time storage you can look into the manufacturer's specs for that hard drive. They will mention this.
Hope this Helps
Thank you for your feedback!
Feb 05, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
what do micro cruzer sandiscs do
your micro cruzer sandisk can perform lots of function .
You can copy your data,songs, video files on your flash drive to use it any time any where .You can do this by just following the simple steps :
1. Plug the USB flash drive to a USB port.
2. A USB flash drive icon will appear on the desktop
3. Double-click on your Cruzer USB flash drive.
4. Select the files or folders you want to copy to the USB drive by clicking on them.
5. Drag and drop the selected files or folders to the USB flash drive icon.
Note : Do not immediately remove your drive from the USB port,right click on drive icon in notification area then click on safely remove the drive ,then remove your drive from your computer.
2: You can take backup of your computer on your flash drive
3.You can also boot from your drive if *********** board support boot from from your flash drive.
May 18, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
how do i load pictures on the flash drive? never used one of these flashdrives before
Loading pictures from usb to computer
1. Put your flash drive into the usb port of your computer.
2. Click on Left Click on Start and Left click on My Computer.
3. There will be a new drive letter, more than likely E:\.
4. You can copy multiple copies or single copy by clicking on one
picture then you can hold down Control key and select the ones
you want to copy.
5. Leave the mouse on the last picture you selected, then right click,
and tell left click on copy.
6. Go to your local drive C:\ and if you want to make a new folder to be
organize, and click on that folder and right click and tell it paste.
Dec 07, 2009 | ASUS Computers & Internet
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
1,009 people viewed this tip
David Payne
David Payne
