Tip & How-To about Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC
How to hide unused links from your Start Menu
It's much better when your desktop menu is customized to your comfort also when you can remove things you don't use and add things you do use.
Follow these very simple steps below:
1. On your desktop "Right-click" on your taskbar (the long bar located at the bottom your screen.
2. Now click on "Properties".
3. Now another dialog will come up, now click on the link "Start Menu".
4. Now click on "Customize".
5. Now another dialog will come up, click on the link called "Advanced".
6. Now let the customization begin.
Microsoft Windows Xp Home Edition Sp2 English Mlp Na Only Additional License (n0901086) for PC Logo
How to improve the performance of a ga 13 engine of a nissan sentra?
Let me tell you that I'm also working on that. :-)..
A nissan ga13ds, since it is carbureted, then it is limited on the amount of modifications that are of good value for money, since some of the top end modifications may cost you the price of a brand new nissan sentra + modifications.
Here are some things I did and are planning: -Replace the stock fuel filter assembly to a high performance one. (ex. to a High flow air filter, cold air intake, short ram intake, etc.) -switch to an electrical fuel pump. -upgrade exhaust system. (performance headers, high flow catalytic converter, larger exhaust pipes, racing mufflers. -upgrade to a better radiator (aluminum) + stronger and better fans. (a cooler engine runs a bit faster) -Install an oil cooler again for the same reason of better cooling. -(just my idea) Buy a performance carburetor. (this may be too costly because you might have have an intake manifold custom built) -Replace engine internals to race internals for better performance under High RPM. -Find or custom build racing camshafts to replace your stock. (this will result to better performance at high RPM levels but will not be efficient running the car in a lower RPM range).
You can also improve the performance of the car itself by doing the following: -Saving weight: -Aluminum wheels -carbon fiber/fiberglass/aluminum hood and trunk. -and any other stuff not necessary to you can be removed to save more weight.
I hope these ideas help.
Oct 09, 2010 | 1996 Nissan Sentra
sys win 32 does not work
reinstall your operating system. Or else better do a thing. follow these steps. go to control panel right click on the add/remove programs Click on Add/Remove Windows components click on Message Queuing details Click on MSMQ HTTP support click ok. click next enter the Xp or ur OS CD in! the windows ll automatically recover its corrupted file!
thanks for making the knowledge share
May 06, 2010 | Dell Dimension 3000 PC Desktop
help?
right click on the desktop and you see ARRANGE ICON BY and there you will see SHOW DESKTOP ICON.
Sep 29, 2009 | Computers & Internet
Problem with new email notification link on IM!
There are 5 things that you must check:
1. At the start menu click on control panel>add or remove programs>set programs and access defaults>custom (there are 3 to chose from): check e-mail
2. At the tools menu click on internet options>programs: check e-mail
3. At the task-bar right click>properties>start menu>customize: check e-mail
4. At the start menu click on control panel>add or remove programs>change or remove programs: check if windows messenger 8.1 is still there 9.0 might need to be repaired. It will say change or remove.
5. At the start menu click on control panel> windows firewall>add a program: add windows 9.0 and make sure 8.1 has been deleted
Nov 06, 2008 | Computers & Internet
440 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
