Tip & How-To about Car Audio & Video
Protected
When hooking up car audio always start by removing the negative terminal from the battery. This will prevent any accidental shorts or blown fuses.
Car Audio & Video Logo
How do I change the batteries?
CHANGING A BATTERY CAN BE EASY DEPENDING ON HOW ACCESSIBLE IT IS..BUT ALWAYS HOOK UP THE NEGATIVE FIRST THAN THE POSITIVE AND JUST REVERSE TAKING OFF POSITIVE FIRST THAN NEGATIVE..DOING IT IN THIS ORDER WILL PREVENT ANY ACCIDENTAL SHORTS..BUT ALWAYS TAKE CARE IN NEVER LETTING THE POSITIVE POST TOUCH METAL..
Feb 21, 2015 | Motorcycles
how to remove radio from 2003 pontiac bonneville
PONTIAC ? BONNEVILLE 2000-2005
1 Disconnect the negative battery terminal to prevent an accidental short circuit.
2 Remove (2) Phillips screws from the instrument cluster.
3 Unclip the ignition trim and remove.
4 Unclip the climate control/radio trim bezel and remove.
5 Depress the spring clips on each side of the factory head unit and remove.
Jan 11, 2011 | Pontiac Car Audio & Video
how do you take out the radio
accidental short circuit. Remove the plastic trim piece to
the left of the glove box and (1) phillips screw exposed.
Unsnap the top edge of the knee bolster panel. Remove
(1) phillips screw from the panel. Remove the ashtray
cluster and (2) phillips screws from each side. Unclip the
entire dash trim bezel and remove.Open doors and
unsnap end caps from each side of dash. Unsnap and
remove radio/instrument cluster panel. Remove (3)
screws in order to remove radio.
accidental short circuit. Unsnap and remove dash bezel.
Remove (3) 9/32" screws and remove radio.
BUICK Rendevous 2002-2007
Feb 11, 2010 | 2002 Buick Regal
how to remove an old stereo from a nissan pulsar?
prevent an accidental short circuit. Remove
(3) screws above the climate controls.
Remove (2) screws from the bottom edge of
the dash trim bezel. Unclip the bezel and
remove. Remove (4) screws securing the
factory head unit and disconnect the wiring
Aug 21, 2009 | Car Audio & Video
moved + bat terminal, now dashboard dials don't work
For safety purposes always always remove the negative side first. This eliminates the possibility of shorting out your wrench against the body or any other negative charged part. There is strong possibility of shorting out the battery which could blow up. This happened to my brother as a kid and he ended up with battery acid in his eyes.
Try unhooking the negative side of the battery as this may reset any relays.
Jan 21, 2009 | 2001 Chrysler Town & Country
718 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
