Tip & How-To about Nokia 5500 Sport Cellular Phone
Menu won't load and phone is laggy?
Don't worry, you can fix it yourself.
1. The problem is this: your memorycard is too full of stuff, or you got too many games or applications.
2. Delete unused, boring and applications that you don't need so much. This should help.
3. If that didn't help, delete your stupid "I'm naked, hahaha" videos and everythin like that.
4. If even that didn't work, you will do the master reset. Just type *#7370# and do what you have to do. NOTICE THIS: This deep reset will delete all information from your games and applications and they won't work anymore! It's your choice.
5. If you don't want to do anything of these: Turn on your phone. Type your PIN etc. In standby, just press menu button once to open your menu. It's slow, but you can live whit it, can you??
_.-¤" DON'T FORGET TO RATE!! ;) "¤-._
Nokia 5500 Sport Cellular Phone Logo
another appiliocatin runnig close it and then start the camera
Try to replace any application that double. It maybe will say operator failed. Don't worry just after u did that. Do the next step.
2. Turn the phone off then turn it on again.
3. Open file manager go to application and try to delete any doubled application. It will maybe show you nothing after deleted. But don't worry. Get out from application folder then open it again. You will find unknown application with the same name of the deleted application that you did before. Just delete it then its gone.
4. Repeat that with every double application or games. If it say failed. Then restart your phone then try and it will be deleted.
Mar 10, 2012 | Sony Ericsson Walkman W810i Cellular Phone
Playing Call of Duty on-line last night and console just went blank. Cannot turn on. Cannot get disk out.
Assuming you've checked basic things like 'fuse in plug' and making sure its all connected up properly and nothing has tripped a breaker switch.
To do a 'hard reset' turn it off at back switch. Then turn it back on at switch. Hold down the power button on the console for about 10 seconds and you should hear two bleeps. then let go. it should then start up.
however if that doesnt work and its entirely mullered you need to send the console back to sony (if in warranty).
You could try phoning them up anyway and seeing what they say about the problem (there might be more 'hard reset' stuff you can do.
If it's out of warranty you have two options.
1. Fix it yourself (it's a dead loss anyway) 2. Buy a new one :(((
If you want to have a shot at fixing it yourself try buying an ebook on it and pulling the thing apart. I wouldn't recommend pulling the console apart without some kind of guide. Ebooks are pretty cheap and a quick google I found this link (below) (it's for red light death etc but seems to show you how to pull the thing apart so don' t worry too much)
Hope this helps and good luck!
http://bit.ly/hLABB0
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
Wii can't read gamecube memory card
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-94
Jun 02, 2009 | Nintendo Wii Console
when starting a game, it says no memorycard inserted in slot 1.
There could be a problem with the actual memory card slot itself.
First try using another memory card just to be 100% sure, and if it still doesnt pick it up i would think (however i am no expert) that there is a problem with the slot.
If this is the case im not sure you can fix it yourself but it may be worth lifting up the slot cover and seeing if one of the contacts is bent -this may be straightenable with a small set of electrical pliers.
If all else fails its best to take it to someone who knows that they're looking at, although sometimes it probably costs less to just buy a new playstation.
Sorry i cant help more.
Feb 28, 2009 | Sony PlayStation 2 Slimline Console
There are no games
1.)try to backup first the data in your memory card to your pc,
2.)after copying ,format your memorycard.
3.)then copy the backup files back to the memorycard{copy it folders by folders}
if still doesnt work the memorycard must be infected by a virus. to troubleshoot:
1.)try to rename the GAME folder to game1{if you cant rename it,rightclick the folder then click properties then uncheck the readonly attributes then click apply then OK.}
2.)after renaming the folder,then create a new folder and name it as GAME
3.)then copypaste the game to the newly created folder.
note: 'GAME' folder indicates the folder where all previously game are located.if the previous name of that folder is '3.71GAME' then the newly created folder must be 3.71GAME
this solution do bypassing the unreadable folder done by a virus,i did it before & it solve my psp problem
tnx 4 using fixya
Oct 17, 2008 | Sony PlayStation Portable (PSP) Console
1,605 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
