"double vision" caused by bad solder points on convergence chips (check...
misenhei
By Apprentice misenhei
Rank: Apprentice
Rating: 100%, 3 votes
posted on Jun 02, 2009
Very Helpful
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able to smack the side of the tv or tap the heat sink for the chips and it corrects the problem than chances are the chips are fine butone or more of the solder points are bad. When I looked at the joints for the chips I noticed hairline cracks around the base of the joint. Re-soldering the joints for the convergence chips solved my problem.
Was this helpful?
Yes
No
3 people thought this was helpful
Can you Help with these Projection Televisions problems?
Hitachi 53UWX10B 53 in. Rear Projection...
what are the deminsions of the mirror
no power on my Hitachi 53uwx10ba tv Power light goes on,...
The TV will not turn on and the indicator light just...
Our tv made a chirping sound then shuts off..its done this...
I've replaced the IC's and the picture has'nt changed the...
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
