Tip & How-To about Kitchen Appliances - Others
How to Clean a Country Living grain mill
One of the most widely used grain mills is the country living grain mill, it is known for its stable build and lifetime warranty. Every so often when you use your grain mill frequently you will need to clean it out to keep it functioning as properly as possible. Luckily cleaning the Country living grain mills are very easy to clean.
First you want to disassemble the grinder, by removing the adjusting knob off of the front of the unit. Make sure that you don't lose the small square piece that keeps the front plate form spinning with the shaft. Behind the knob you will find some washers and the burr. You can take out the burr and use a small brush to clean out any flour than may have gotten caught inside.
Some times you will need to clean the grinding plates this can be done by using the wrench that came with the mill to remove the screws that hold the stationary plate in place. When the plates have been disconnected they can be taken out of the unit for a more thorough cleaning. If you wash them in water make sure that you dry them well immediately to prevent them from rusting. These grinding mills were not made to be washed in water, therefore just using a damp cloth should be thorough enough to clean the whole unit.
When you have finished washing and drying the pieces its time to assemble your mill. Before you put the plate back inside make sure that there is nothing inside the unit because the plate will not reattach if anything is in the way, all the mounting hole have to align before you move on to the next part of the mill. Then follow the disable instruction the reverse order, replace the burr, washers and knob. Wallah! you now have a clean grain mill ready for use.
Kitchen Appliances - Others Logo
Can I grind coffee in an electric grain mill?
Electric grain mills were not designed to grind up oily grains like coffee, you would be better off getting either a hand grinder or a coffee grinder.
Jan 23, 2014 | Kitchen Appliances - Others
Are there automatic grain mills? I've only been seeing hand mills on Amazon.
Most of the mills that you will see on sites like amazon are hand mills but I found the Nutrimill to be a really amazing machine mill, its quiet and quick and has many different settings. EQUIP Nutrimill Grain Mill Amazon com Kitchen Dining
Can I use a coffee grinder to mill grains?
You can although I have found that the coffee grinder doesn't mill the grains down to a fine enough powder for making flour though.
What is Quarter-Sawn Lumber?
Quarter-sawing is a method of milling trees into lumber. Quarter-sawn lumber is highly sought after, particularly in certain species such as oak or maple, where look of the grain in the wood is accentuated by the method of cutting the tree. While rip-sawing is the most efficient (and common) method of milling, quarter-sawing is more difficult to cut but yields much more stable lumber. Because it is more difficult to cut and there is more waste, quarter-sawn lumber is considerably more expensive than rip-sawn material.
(taken from http://woodworking.about.com)
Feb 27, 2013 | Crafts & Hobbies
how does a stone grain mill work?
The equipment uses the most advanced processing technology, the production process can be divided into three steps:
1.Cleaning workshop process: This process includes thrice sieving, twice hit, twice destone, once select, thrice magnetic separation, once dampening. Cleaning out the middle and small impurity from grain. This section is to prepare for milling part and to protect the machinery as well. The process has good cleaning effect, high output, low power consumption, good dust removal effect and no dust outside.
2. Flour milling process: Adopt 4 skin grinding, 7 core grinding, 1 grinding mill, 2 tail, 2 beat, 1 brush, 5 clear flour, 3 skin, 4 skin, 1 core grinding powder process.
3. Packing process: Use quantitative automatic packing machine for weighting and packing the flour into bags.
Jan 24, 2013 | Kitchen Appliances - Others
823 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
