Tip & How-To about Drywall
Cutting Drywall Like a Pro
Cutting drywall is one of the more easy cuttings that you will do when remodeling your house although you hear all kinds of horror stories of people making huge mistakes and having to re-hang drywall or use exorbitant amounts of putty to fix mistakes. Following just a few simple tips you can master the task of cutting drywall.
Most of the cuts that you will be doing will fall under the category of score, snap, cut. Because dry wall is fairly easy to cut, for a majority of cuts you will just need a scoring knife with just enough pressure to cut the paper and then you will be able to snap the drywall then you have to cut the paper on the back side and you are done.
For the major cutouts that you will be doing like doors and windows, the best way to go about doing them is to measure and cut the boards before you hang them. Its best to have someone help you hold the board in place.
There are two main types of saws that you will use a drywall rip saw and a keyhole saw. They each have their purpose and they should only be used for the purposes that they are meant for. The keyhole saw is for small cuts like holes for light fixtures, outlets and switches while the rip saw is for cutting drywall down to size like for doors and windows.
Once you have mastered the basics of cutting drywall you will be able to do more advanced home repairs and will spend less time worrying about cutting out pieces of drywall.
Drywall Logo
i want to replace my vanity top in the power room. i vanity top touches the wall on each side. I have measured wall to wall and it's 36 inches wide but all standard vanity tops are 37 inches wide. To custom make one is double the price and i don't want to do that. anyway to get around this problem? I have heard of cutting into the drywall to allow the extra inch to go into the drywall, Has anyone done this before, if so how do u do it?
yes simply remove the drywall from both sides of where you are installing the cabinet then either cut the old pieces to fit above and drywall tape over the seam where you cutthe old piece out or get a new piece of drywall and cut it to fit into the space above alternatively you can try to cut into the drywall perfect fit which you would then just silicon around to fill the seam
Jan 10, 2015 | Televison & Video
paint bubbles on drywall
It's been almost 10 months since the question was posted so how does it look? Most bubbles appear under the drywall tape or could be from primer / paint being rolled over drywall dust. Tape bubbles don't go away. These need repaired by cutting out the bubbled tape and filling in with compound. Tape bubbles can be avoided by using a TapeBuddy taping tool. This tool applies compound directly to the tape so there are no dry spots under the tape. Hope this helps.
May 05, 2014 | Drywall
What are rasps how are they different from other saws?
Rasps are used if you want to shave off small pieces of drywall, like if the line you cut isn't perfectly straight. Other saws are used more for cutting peices in half or cut out shapes. Make sure you wear a mask because rasping makes a lot of dust!
Sep 09, 2013 | Drywall
is there a tool that will make it easier to cut out a perfect circle?
Circles are hard to make, I had a lot of trouble when we decided to put recess lighting into the whole house. I wasn't able to find a tool that does all the cutting for you but what worked really well for me was a Goldblatt Drywall Circle Cutter. It doesn't cut all the way through the drywall, it just scores it so that all you have to do is cut from the center of the circle out to the edge and then snap off the pieces. Saves you tons of time trying to get those round edges to look perfect!
I have changed the engine and there is no fire. Tried changed the distributor and the crank engine sensor but still no fire The starter is turning the engine over but when i take a look at the spark plugs i get no fire although if i look at my injectors gas is arriving. Have any ideas what my problem is?
I have heard of these horror stories about cutting the wires on the ecu and splicing them back together to get the new engine running. We just did a motor and thought we were going to have to do that but the thing fired right up and ran perfect. We couldn't believe it. Anyway, I would try the ignitor, check the fuses, check the oil? Check the immobilizer? How about the ?? There has to be something you are overlooking. Did you get a new ecu with the new motor? Is everything hooked back up? No wires left disconnected? Hope this helps.
Apr 14, 2010 | 2001 Nissan Altima
1,057 people viewed this tip
Top Drywall Experts
Tim Hunt
Tim Hunt
ray gallant
Bill Boyd
Are you a Drywall Expert? Answer questions, earn points and help others
