Tip & How-To about Retail Supplies
First Time Dressing a Mannequin? Read This!
When dressing your mannequin, it's important you find the articles of clothing. The clothes must fit the mannequin properly and they mustn't have any wrinkle or creases. Make sure to steam/them the clothing on both sides of the garment. Remove the tags on the clothing if they can't be hidden.
Always start from the bottom of the mannequin and work your way up, leaving outer layers last to ensure they do not crease or wrinkle.
If the mannequin's legs are close together and you can put the pants on without detaching them, do so. In this case, it's best to put the mannequin in a seated position with its legs out straight ahead.
If you are unable to fit the pants on the mannequin's legs while they are attached, remove the legs and put the pants on separately. You can then reattach the legs when you are finished. If this is your first time reattaching the legs, ask for help because this part can be tricky.
Once you get to the torso of the mannequin, you may find you are working with a shirt without zippers or buttons and can't be opened. In this case, you will need to remove the arms from the torso before you begin. You can then put the arms back into place when you have finished.
If you are working with sitting/reclining mannequins, you will find it can be difficult to dress them in certain styles of clothing, such as tight jeans. You may also need to use larger sizes in order to fit them. It may be difficult to layer the clothing on these types of mannequins. You may also have similar difficulties dressing mannequins with bent arms.
Always take a final look at your mannequin to check and see everything looks right, the buttons are done up, etc.
Once you become more experienced with dressing a mannequin, you will be able to spend more time in styling them with the right accessories, popping the collar on a shirt, or just rolling up their sleeves to bring some life into your display.
Retail Supplies Logo
Do you think it is important to wear fashionable clothes.
Fashion is the only factor which should be considered by people because people judge other people by their clothing. Good clothing can make an impression and make your all task easy, but it is necessary that you should have the knowledge of current fashion trend. Get more about women clothings at http://www.ebay.co.uk/usr/impreshunzltd
Jun 12, 2014 | Home
Can you order wedding gowns online?
Yes, you can do it. There are tonnes of sites that deals with wedding dresses. You just need to check them and place your order. Online stores provide you a large variety to choose.
http://www.procuffs.com/
Feb 27, 2013 | Clothing
are mannequins used for anything other than selling clothes?
Yes, mannequins are also used in CPR classes to illustrate how to save a suffocating person, and more generally by doctors teaching medical classes. They were also used in the 1950s to show the effects of nuclear weapons on humans.
Jan 13, 2013 | Retail Supplies
when were mannequins first used?
mannequins were first used in the 15th century to show clothes models on miniature dolls, but the first life-sized mannequins were used in France in the 18th century
857 people viewed this tip
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
