Tip & How-To about Televison & Video
Using a video transmitter to extend your cable network to another TV in the house
When I first purchased a cable plan I only had one TV in my house and it seemed like a waste to get multiple cable boxes for TV that I had not yet purchased. When the prices came down on TVs I decided that it was time to get a set to go in my bedroom upstairs but I didn't have a cable box to connect to the set.
I could have gone out and spent a $100+ on a new bulky cable box that is not really all that pretty or I could get a video transmitter that will extend my signal to the upstairs TV set for around $50. Even though it takes a little bit of set up the results are great, I can even use the one remote on both television sets.
To set up your video transmitter first you have to take the transmitter and receivers out of the box and make sure that they are both set to the same channel. This will ensure that they will read each other. Then you take the cables that came with the transmitters and connect them to the back of the cable box, matching up the yellow, red and white cables to each other. Position the transmitter box so that it is lined up with the signal transmitter of the cable box.
Then you want to go upstairs to the second TV and connect the receiver to the back of the television set the same way that you connected the transmitter to the cable box. Take the remote from the set downstairs and it should have extended the connection of the cable box to both TV sets. Now you are able to control the cable box from upstairs and watch your stations on both TVs.
Televison & Video Logo
we bought a new samsung 32" flat screen TV. Our HD cable box is connected to the tv using the red/yellow/white cables. Is there an alternative way to connect my Wii without unplugging the HD box every time?
You'll need to purchase an HDMI cable and use that to connect your hd box to your tv. Your tv should have several HDMI connections on the back to facilitate the hookup and you will not have a true HD picture without that cable. You can buy this cable from the same place you bought your tv or www amazon.com as well as many other electronics supply stores, hardware stores, or places like Kmart, Walmart, Bimart, etc. You can also buy a multi port Rh connector box that you can run multiple components through and just push the corresponding button for the component you wish to operate.
Hope this helps and please rate my solution!!
Nov 27, 2010 | Nintendo Video Game Consoles & Games
TV volume is half of want it should be.
the problem is not the cable into your house, but the amplifier it self, if the amplifier is not been powered if a rightful voltage, that can happen. if you are not happy with the output than take your tv to a repair shop, so that an amplifier can be worked on.
Mar 16, 2009 | Panasonic TH-42PZ77U TV
Help pleaseALREADY PURCHASED PREMIUM PLAN?????
The remote receiver IC costs $8 + shipping from andrewselectronics.com
Just fixed this model 2 days ago with the same symptoms.
Mar 30, 2008 | Toshiba 36AF42 36" TV
940 people viewed this tip
Top Televison & Video Experts
