Tip & How-To about Sharper Image SI564 Clock Radio
How to set the time & alarm for SI564
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} After several unsuccessful attempts to locate a user manual for this clock radio, I discovered for myself how to set the time and the alarm for this model by trial & error. Hope this tip helps others!
Press the MODE button located on the top of the clock. The screen blinks the hour with "AL HOUR?" specified. Press the SELECT button to go forward or the PRESET button to go backward. Press the MODE button again to set the "AL MINUTE?" Subsequent presses of the Mode button scrolls through AL BUZZER, AL VOLUME, HOUR, MINUTE, DUAL HOUR, 12/24 HR, YEAR, MONTH, DATE, temp F or C, AREA features. It seems that the clock saves the last setting you made once you stop pressing any buttons.
Sharper Image SI564 Clock Radio Logo
set time on RCA dual clock radio with fashion wrap? RCR 8622
I love the form of your question, as I wanted to wing the sucker myself, but got online before I actually pulled an Office Space on it. I found nothing, but I DID actually figure it out. Not super intuitive though. To set the time: Hold down the memory key in the middle until the number flashes. Use the arrow up/down on the right to set hour. Press Memory key again, repeat with arrow keys to set minutes. Hit memory key again. Alarm: Press/hold the Alarm button until the Alarm 1 or 2 flashes and press the side you want, 1 or 2, to set. Arrow time up/down, then do minutes, press alarm 1 again, select alarm or tuner, press alarm 1 again. Now I need to see if it will work in the morning. I know the flipping time is set though! Good luck. If you wing it, please post photos! :D
Dec 11, 2014 | RCA Audio Players & Recorders
I need a manual for a Vextra CD/Clock Radio VX715. I can not figure out how to set the clock radio alarm
The settings on this clock were difficult to figure out even with the manual. I made a lot of notes in the manual to help myself each time I had to reset the clock and CD Alarm. See Attached .pdf.
Nov 13, 2010 | Audio Players & Recorders
alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
1,259 people viewed this tip
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
