Tip & How-To about Simplehuman Sensor Soap Pump ST1001
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
Simplehuman Sensor Soap Pump ST1001 Logo
How do I Install batteries in simple human soap dispenser
The hunt for batteries is over with the introduction of simplehuman's new rechargeable sensor soap pump. The newest sensor pump has a battery that recharges with a USB power adaptor, ensuring users of the product will have an "always-on" touch-free soap dispensing experience, every time. Do you have the port for the USB adapter on your unit? If so, you don't have to replace, just charge.
Aug 28, 2014 | Simplehuman Color-cap Sensor Pump by...
soap dispenser quit working
Need to flush it with fresh water. Fill an old soap bag (or whatever it uses) with clean water and let it flow as much as possible till empty.
Jun 28, 2012 | Simplehuman Sensor Soap Pump ST1001
how do I prime the pump on the simplehuman soap dispenser
Here are the priming instructions from simplehuman.com: deborahpcb.jpg
It says if you are having priming issues, use an un-bent paper clip to (GENTLY!) poke the valve opening. Be careful, because you might puncture the rubber seal.
Apr 20, 2011 | Simplehuman Soap Sensor Pump No Hands...
I have a Simple Human 14 oz sensor Soap Dispenser
This is what I found in the Simplehuman FAQ's. I had to wait about 30 minutes for the light to stop blinking, but it seemed to work for me.
If the pump is unresponsive or the blue light is flashing, fresh batteries should resolve this issue. Please power off the pump completely. Once the pump is turned off, remove the old batteries. Please wait for the pump to reset (until the flashing light stops and preferably letting it rest overnight) before you install the new ones.
Aug 05, 2009 | Kitchen Appliances - Others
1,209 people viewed this tip
Top Simplehuman Plumbing Experts
Donni Steen
Tom Chichester
Are you a Simplehuman Plumbing Expert? Answer questions, earn points and help others
