Tip & How-To about Water Sport
Keep the stink out of your water shoes
Water shoes are great for taking hikes and having fun in the water but they can also be breeding grounds for fungus and bacteria that if they are not cleaned and dried properly after use will cause them to start to smell really bad. Luckily cleaning most water shoes is really easy and only require things that you probably already have in your kitchen.
What you are going to need is a clean sink, some soap (can be hand soap or dish soap), baking soda, and a sponge.
Start by loosening the straps on your water shoes if they have them, then place the shoes in the sink. Fill the sink with warm water and add in a tablespoon of soap. Then add half a cup of baking soda to the water.
Take your sponge, get it a little wet and sprinkle it with a teaspoon of baking soda. Use the sponge to scrub the shoes both inside and out. Once they are all scrubbed let the shoes soak in the soapy water for about half an hour.
After half an hour come back and let the water dair out of the sink, then rinse off the shoes with warm water inside and out making sure all the soap is gone.
Using a towel dry the shoes and make sure that there is no more moisture before putting them away. If there is still an odor sprinkle a little bit of baking soda on them overnight, then in the morning rinse and dry them again.
Make sure that you wash and dry your water shoes after every use to keep them from smelling. You can also use activated charcoal disks to prevent odor by putting a disk in your shoes over night.
Water Sport Logo
Do warm mist humidifiers accelerate the growth of bacteria?
A warm mist as humidifier is advised only in cold climates in the winter months because warm water is a perfect breeding ground for bacteria.
Sep 05, 2012 | 1topstore Fish
there is a terrible smell from my washer
Hi, what happens is that water sits at the bottom of the discharge pipe, as well as a build up of "gunk", which is a great breeding ground for bacteria and such. So during the first rinse out, the smelly water and gunk is discharged into the drain, and the smell comes up from the laundry tub drain. Pour a few cups of bleach into the discharge hose and let it sit for an hour. This will kill all the nasties. Then just run the machine once through to pump out the bleach.
Sep 09, 2010 | KitchenAid KHWS01PMT Front Load Washer
817 people viewed this tip
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
